Not stop record 1.37.55~20240313084849-jammy
borozenetsww
Post by borozenetsww »
1.37.55~20240313084849-jammy not stop record after move detection out.
Снимок экрана 2024-03-14 113232.png (147.23 KiB) Viewed 1649 times
Re: Not stop record 1.37.55~20240313084849-jammy
i'm in mocord - I guess this also explains all my cams stay in alarm/red highlight....montage view.
Anna.N
Post by Anna.N »
Same problem here with zoneminder_1.37.55~20240313.153-bookworm_amd64
Once motion is detected it keeps on recording even if the trigger event is gone. Alarm remains on (red frame). Setting is OnMotion.
phil56
Post by phil56 »
After my update yesterday, same thing, the recording starts with a detection and doesn't stop. It is cut into 5-minute segments
edit:
The cause ? https://github.com/ZoneMinder/zoneminde ... 5dae3a42b5
