Problem clicking to a specific spot during event playback
ZMBrian
Post by ZMBrian »
I'm currently using 1.36.32, but this problem has persisted for me through several previous versions of 1.36 (and maybe even earlier). I did not have this problem with versions from about 3-4 years ago.
My cameras are in MOCORD recording at 10 min event intervals. During event playback, there is a playback progress bar (for lack of a better description) at the bottom that highlights detected motion in red. I can not click to anything early in the playback within about the first 2 minutes 20 seconds, it will simply go to the end of the recording. I can click to any point in the playback after about 2 minutes 20 seconds without issue. This is frustrating because if motion is detected at about the 2 minute mark, I have to wait the full 2 minutes to see it, I can't click ahead to right before the motion detection. If I do, it goes to the very end of the recording. Is this a known issue? Is there a work around?
Re: Problem clicking to a specific spot during event playback
Not a known issue. I reworked a lot of that code in master... might be interesting to see if it does it. I reworked it because it was kinda broken so it may be that I have not merged something back to 1.36.
raptor320d
Post by raptor320d »
Hi Iconnor, and the Otherones,
at first, I thank you Iconnor for your effort.
im using ubuntu 22.04, yesterday I donwload version 1.36.33 BUT problem with playback still here.
I feel the problem from 1.36.x
this is reason i'm using ubuntu 18.04 for 2 years
problem definition:
you must mocord, and you take it - no mather what time and what speed you need, everything fa.k you =)
you not be abble take more than 1x speed and it is big problem to change a time position
this problem is times describe (not only) in this forum
please take it with a smile =)
thank you a lot
thanks in advance
Regards Petr
ps: (sorry for my english - still lerning)
FWIW, I'm not seeing this. I'm curious about your record settings, because I HAVE seen it, but fixed by changing record settings. Or so as I recall - it's been awhile.
And you are talking about recordings made by the current version ZM, not some old recording, I trust.
raptor320d
hi dougmccrary
where is "record settings"?
there is camera/source or options, but nowhere something like "record"
Yeah, sorry about that - Storage tab for the camera/monitor. Video Writer
Some cams seem to not work well with camera passthrough. One of mine is Encode, Auto, libx264 for e.g.
raptor320d
okok, i feeel it, this will be the problem, you can punch me
settings is:
  • Storage area: my one
    [--]from there, everyting is default[--]
  • Save JPEGs: Frames + Analysis images (if avail.)
  • Video Writer: disabled
  • Optional Encoder Parameters (?): # Lines beginning with # are a comment
    # For changing quality, use the crf option
    # 1 is best, 51 is worst quality
    crf=23
the last one - it is true?
second problem: why the timestamp disapears, it is still set
Save .jpgs is useful for reviewing zone settings. You can turn that off or just to anlaysis images only.
Then turn on encoding with auto auto - that will enable your timestamp to be recorded.
Also, while it's not supposed to cause problems, it seems to help to remove those comments above crf=36
Let it run awhile and see what you get.
BTW, I'm not sure how long, if ever, it takes debug settings to get read, but a restart does it.
raptor320d
problem is suppressed, i setup x254 codec, with "auto" it doesnt work properly.
it works, but the cursor hopping when i set some time (position)
but works
second problem with timestamph was like this:
viewtopic.php?t=30228
in the log in gui i can see that defalut font is in the ./zoneminder/fonts instead of /zoneminder/www/fonts
thanks dougmccrary
raptor320d
the problem is almost the same,
i can select any position, BUT, "mocord" record in 10 minutes block.
every video seem to be 9:59 in the description, but when i try to see it, it have only about 15 sec.
setting is:
Save JPEGs: Frames + analysis
Video Writer: encode
h254
libx254
#crf=23
almost the same like version 1.34
please help
h254
libx254
#crf=23
please help
Top
probably drop JPEGs to analysis only
In optional params, just "crf=23" no quotes
Options->Config has EVENT_CLOSE_MODE time ?
