Recording Problems
attila123
Recording Problems
Post by attila123 » Mon Apr 27, 2015 1:34 am
Hey all I'm new here :)
I've recently installed Zoneminder 1.28.1 on Centos 6.6 64 bit on a virtual machine and I'm getting this problem that seems to be filling up my hard drive with bogus events at an insanely fast rate.
This is an example of it (I uploaded to imgur but this forum won't let me link it properly) and it seems to happen every 2-5 seconds imgur(.)com/Fz5gx2r.jpg
The camera I'm using is a Hikvision DS-2CD2032-I and on it's own web interface this never happens.
Any help would be appreciated thank you.
asker
Re: Recording Problems
Post by asker » Mon Apr 27, 2015 1:40 am
Is your source type ffmpeg?
attila123 wrote:Hey all I'm new here :)
attila123
Post by attila123 » Mon Apr 27, 2015 1:44 am
asker wrote:Is your source type ffmpeg?
Yes it is.
asker
Post by asker » Mon Apr 27, 2015 1:47 am
Try the native rtsp option or other strategies
http://www.zoneminder.com/wiki/index.ph ... SP_streams
Yes it is.
attila123
Post by attila123 » Mon Apr 27, 2015 2:12 am
Okay so I've tried every single other option and I just get blank screens with Remote and VLC, only setting that works is the ffmpeg and RTP/RTSP link. I have set the maximum frames to way higher than the camera can actually do and I think that has done the trick, I will test it out for about an hour and report back on any smudging events.
Edit: Yup increasing the fps seems to have done the trick, I set it to 40 fps while the camera is running at 3 mp 20 fps.
Post by bbunge » Wed Apr 29, 2015 1:34 am
The Maximum FPS in the ZM Monitor setup is for local cameras. Value should be (blank) for everything else.
bb
asker
Post by asker » Thu Apr 30, 2015 12:35 am
bbunge wrote:The Maximum FPS in the ZM Monitor setup is for local cameras. Value should be (blank) for everything else.
bb
Actually, it should be set to a value higher than the FPS of your in-camera setting. If you don't and your camera goes offline, ZM eats up all the CPU.
