Cams not working on Opensuse 12.3 with zm 1.26.4
tkmbe
Post by tkmbe » Sun Mar 02, 2014 9:33 pm
I try to use zm 1.26.4-9..86_64 from the following repository
http://www.zoneminder.com/wiki/index.ph ... s_for_SuSE
I tried the following cams:
1. aircam Firmware 1.2
Tried the ffmpeg mode as described in the wiki. This gives the following error:
Mar  2 15:07:22 gw1 zmdc[12021]: INF ['zmc -m 1' starting at 14/03/02 15:07:22, pid = 26566]
Mar  2 15:07:22 gw1 zmdc[26566]: INF ['zmc -m 1' started at 14/03/02 15:07:22]
Mar  2 15:07:22 gw1 zmc_m1[26566]: FAT [You must have ffmpeg libraries installed to use ffmpeg cameras for monitor 1]
Mar  2 15:07:22 gw1 zmdc[12021]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Mar  2 15:07:22 gw1 zmdc[12021]: INF [Starting pending process, zmc -m 1]
Mar  2 15:07:22 gw1 zmdc[12021]: INF ['zmc -m 1' starting at 14/03/02 15:07:22, pid = 26579]
Mar  2 15:07:22 gw1 zmdc[26579]: INF ['zmc -m 1' started at 14/03/02 15:07:22]
Mar  2 15:07:22 gw1 zmdc[12021]: WAR [Can't find process with command of 'zma -m 1']
Mar  2 15:07:22 gw1 zmc_m1[26579]: FAT [You must have ffmpeg libraries installed to use ffmpeg cameras for monitor 1]
Mar  2 15:07:27 gw1 zmwatch[12167]: ERR [Memory map file '/dev/shm/zm.mmap.1' should have been 896 but was instead 0]
Mar  2 15:07:27 gw1 zmdc[12021]: INF [Starting pending process, zmc -m 1]
Mar  2 15:07:27 gw1 zmdc[12021]: INF ['zmc -m 1' starting at 14/03/02 15:07:27, pid = 26680]
Mar  2 15:07:27 gw1 zmdc[26680]: INF ['zmc -m 1' started at 14/03/02 15:07:27]
Mar  2 15:07:27 gw1 zmc_m1[26680]: FAT [You must have ffmpeg libraries installed to use ffmpeg cameras for monitor 1]
I'm using ffmpeg version 2.0.1.3.7.x86_64 from pacman repository
Trying to use snapshot mode will give the following erros trying to show the monitor:
Mar  2 18:17:21 gw1 web_php[13239]: ERR [socket_sendto( /var/run/zm/zms-943619s.sock ) failed: No such file or directory]
Mar  2 18:17:21 gw1 web_php[13239]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-943619s.sock ) failed: No such file or directory - checkStreamForErrors()]
2. apexis
Tried to use http simple mode as described gives the same error as for aircam and http mode :-(
Mar  2 17:56:42 gw1 zmc_m1[12956]: INF [Starting Capture]
Mar  2 17:57:08 gw1 zmc_m3[12223]: INF [apexis: 1000 - Capturing at 10.42 fps]
Mar  2 17:57:28 gw1 web_php[7597]: ERR [socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory]
Mar  2 17:57:28 gw1 web_php[7597]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory - checkStreamForErrors()]
Mar  2 17:57:34 gw1 web_php[7597]: ERR [socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory]
Mar  2 17:57:34 gw1 web_php[7597]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory - checkStreamForErrors()]
Mar  2 17:57:40 gw1 web_php[7597]: ERR [socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory]
Any hints what could be the problem?
I have also given full right access to the /var/run/zm directory...
I tried also to compile the sources but fails too...
monex
Re: Cams not working on Opensuse 12.3 with zm 1.26.4
Post by monex » Thu Mar 27, 2014 7:21 pm
the socket is destroyed because there of the missing ffmpeg support. It looks like you have chosen the wrong version.
To enable ffmpeg support in ZoneMinder you have to install the MP package. Simply use this link: http://www.liquid-co.de/pub/suse/one-cl ... der-MP.ymp and follow the one click install instructions. During installation you must choose one packman repository in order to install the MP Package.
Hope this helps
Dirk
Users browsing this forum: No registered users and 11 guests
