http://www.zoneminder.com/wiki/index.ph ... s_for_SuSE
I tried the following cams:
1. aircam Firmware 1.2
Tried the ffmpeg mode as described in the wiki. This gives the following error:
Mar 2 15:07:22 gw1 zmdc[12021]: INF ['zmc -m 1' starting at 14/03/02 15:07:22, pid = 26566]
Mar 2 15:07:22 gw1 zmdc[26566]: INF ['zmc -m 1' started at 14/03/02 15:07:22]
Mar 2 15:07:22 gw1 zmc_m1[26566]: FAT [You must have ffmpeg libraries installed to use ffmpeg cameras for monitor 1]
Mar 2 15:07:22 gw1 zmdc[12021]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Mar 2 15:07:22 gw1 zmdc[12021]: INF [Starting pending process, zmc -m 1]
Mar 2 15:07:22 gw1 zmdc[12021]: INF ['zmc -m 1' starting at 14/03/02 15:07:22, pid = 26579]
Mar 2 15:07:22 gw1 zmdc[26579]: INF ['zmc -m 1' started at 14/03/02 15:07:22]
Mar 2 15:07:22 gw1 zmdc[12021]: WAR [Can't find process with command of 'zma -m 1']
Mar 2 15:07:22 gw1 zmc_m1[26579]: FAT [You must have ffmpeg libraries installed to use ffmpeg cameras for monitor 1]
Mar 2 15:07:27 gw1 zmwatch[12167]: ERR [Memory map file '/dev/shm/zm.mmap.1' should have been 896 but was instead 0]
Mar 2 15:07:27 gw1 zmdc[12021]: INF [Starting pending process, zmc -m 1]
Mar 2 15:07:27 gw1 zmdc[12021]: INF ['zmc -m 1' starting at 14/03/02 15:07:27, pid = 26680]
Mar 2 15:07:27 gw1 zmdc[26680]: INF ['zmc -m 1' started at 14/03/02 15:07:27]
Mar 2 15:07:27 gw1 zmc_m1[26680]: FAT [You must have ffmpeg libraries installed to use ffmpeg cameras for monitor 1]
Trying to use snapshot mode will give the following erros trying to show the monitor:
Mar 2 18:17:21 gw1 web_php[13239]: ERR [socket_sendto( /var/run/zm/zms-943619s.sock ) failed: No such file or directory]
Mar 2 18:17:21 gw1 web_php[13239]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-943619s.sock ) failed: No such file or directory - checkStreamForErrors()]
Tried to use http simple mode as described gives the same error as for aircam and http mode
Mar 2 17:56:42 gw1 zmc_m1[12956]: INF [Starting Capture]
Mar 2 17:57:08 gw1 zmc_m3[12223]: INF [apexis: 1000 - Capturing at 10.42 fps]
Mar 2 17:57:28 gw1 web_php[7597]: ERR [socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory]
Mar 2 17:57:28 gw1 web_php[7597]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory - checkStreamForErrors()]
Mar 2 17:57:34 gw1 web_php[7597]: ERR [socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory]
Mar 2 17:57:34 gw1 web_php[7597]: ERR [getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory - checkStreamForErrors()]
Mar 2 17:57:40 gw1 web_php[7597]: ERR [socket_sendto( /var/run/zm/zms-387509s.sock ) failed: No such file or directory]
I have also given full right access to the /var/run/zm directory...
I tried also to compile the sources but fails too...
