problem after upgrade to 1.26.4
topromotion
Post by topromotion » Mon Nov 18, 2013 9:31 pm
Hello!
After upgrading from 1.25.0 to 1.26.4 i have a problem - all monitors stay a red color in list, and in log lots of error like that:
Memory map file '/dev/shm/zm.mmap.20' should have been 896 but was instead 0
Can't run query: Unknown column 'Colours' in 'field list'
'zma -m 21' exited abnormally, exit status 30
I use a Dlink ip camera dcs-932l, its works through http.
chippy99
Re: problem after upgrade to 1.26.4
Post by chippy99 » Tue Nov 19, 2013 1:19 am
Did you run zmupdate.pl to update the database ? It seems to be complaining about a missing column in your database.
topromotion
Post by topromotion » Tue Nov 19, 2013 6:49 am
Yes, i am run a zmupdate.pl, and upgrading of db pass succesfuly/
topromotion
Post by topromotion » Tue Nov 19, 2013 6:57 am
i have another pc with zoneminder 1.25.0, in /dev/shm/ have a several files like zm.mmap.10, zm.mmap.11. But after update this files disappeared
chippy99
Post by chippy99 » Tue Nov 19, 2013 2:34 pm
Clutching at straws but have you set monitor colour space to 32 bit ?
mastertheknife
Post by mastertheknife » Tue Nov 19, 2013 2:37 pm
Execute the SQL statements below to fix this manually:
ALTER TABLE `Monitors` ADD `Colours` TINYINT UNSIGNED NOT NULL DEFAULT '1' AFTER `Height`;
ALTER TABLE `Monitors` ADD `Deinterlacing` INT UNSIGNED NOT NULL DEFAULT '0' AFTER `Orientation`
Kfir Itzhak.
topromotion
Post by topromotion » Tue Nov 19, 2013 2:42 pm
mastertheknife wrote:Hi,
Thank you! Its works for me! =)
