Has anyone had any luck getting this camera to work with ZoneMinder?
I entered all of the data for RTSP (which I verified was working by opening a connection with VLC). I can't get the camera to work. On the monitor page, it shows as green (connected), but when I click through to try to get the video, nothing renders.
Any help would be greatly appreciated!
Y-CAM Bullet HD 1080P YCBLHD6
Re: Y-CAM Bullet HD 1080P YCBLHD6
Attaching a screen shot of my config for the camera.
- Here's the config I have for the camera.
- y-cam-settings.JPG (43.76 KiB) Viewed 2636 times
Re: Y-CAM Bullet HD 1080P YCBLHD6 - SOLVED
I solved this myself, it doesn't work with rtsp, but it does work with FFMPEG.
I don't know what the difference is, or why this would work and that doesn't, but it seems to be going now.
- screenshot-jpg.jpg (37.41 KiB) Viewed 2625 times
