Y-CAM Bullet HD 1080P YCBLHD6
transcon
Post by transcon »
Has anyone had any luck getting this camera to work with ZoneMinder?
I entered all of the data for RTSP (which I verified was working by opening a connection with VLC). I can't get the camera to work. On the monitor page, it shows as green (connected), but when I click through to try to get the video, nothing renders.
Any help would be greatly appreciated!
transcon
Re: Y-CAM Bullet HD 1080P YCBLHD6
Post by transcon »
Attaching a screen shot of my config for the camera.
Here's the config I have for the camera.
transcon
Re: Y-CAM Bullet HD 1080P YCBLHD6 - SOLVED
Post by transcon »
I solved this myself, it doesn't work with rtsp, but it does work with FFMPEG.
I don't know what the difference is, or why this would work and that doesn't, but it seems to be going now.
