OK! I hope I’m putting this in the right place.
I have about 25 Ganz ZN-C1M Cameras on site and working.
I would like to get them working on my ZM system if that's possible. If anyone has any experience with these type of cameras and ZM I would be forever grateful for some help on getting set up.
Thanks for your time and reading my post.
Joe Peterson
GANZ ZN-C1M Camera and Zoneminder 1.24.2
Camera Specs.
Here are the specs. for the GANZ ZN-C1M Camera.
I will do some port forwarding and get one of them on the net.
Thanks for your help and will get back to you just as soon as I have you one to look at..
Joe
Sensor 1/2.5" Progressive Scan CMOS
Max. Resolution 1080p 720p VGA
Effective Pixels 2560 (H) x 1920 (V)
White Balance ATW / MANUAL (PRESET)
Digital Zoom 8x
AGC Yes
BLC (Backlight Compensation) Yes
Iris Manual / DC Auto Iris
Shutter Speed 4, 1/10, 1/12.5, 1/15, 1/20, 1/25, 1/30, 1/50, 1/60, 1/100, 1/120, 1/240, 1/480, 1/960, 1/1024, 1/2000 s
Lens Mount CS/C (Adapter)
Day/Night Performance IR Cut Filter, True Day/Night
Dynamic Range 70.1 dB
Min. illumination Color: 0.7 lux (F1.2, 30IRE), B/W: 0.08 lux (F1.2, Slow Shutter ON, 30IRE)
ANALOG
Video Signal NTSC/PAL selectable
Monitor Output Composite Output (BNC), 75 ohm 1Vpp
Scanning Frequency NTSC: (H) 15.734 kHz, (V) 59.94 Hz / PAL: (H) 15.625 kHz, (V) 50 Hz
Resolution Horizontal: 600 TVL or more / Vertical: 350 TVL or more
NETWORK
Network 10BASE-T, 100BASE-TX, RJ45
Image Compression
H.264: - Main Profile, Simple / Advanced Mode, Base Profile (D1 resolution only)
MJPEG - 2nd stream only
Resolution
1920 x 1080, 1280 x 720, 1280 x 720 (Wide),
1280 x 1024, 1024 x 768, 640 x 480,
320 x 240
640 x 480, 320 x 240
Protocol IPv4/6, HTTP, HTTPS, SMTP, UPnP, DNS, Dynamic DNS, NTP, RTSP, RTP, TCP, UDP, IGMP, RTCP, ICMP, DHCP, ARP
Frame Rate 2.5 fps ~ 30 fps
Web Browser Internet Explorer 7.0 or above, PDA / Smart phone
Security Password Protection, HTTPS, IP Addressing Filtering
SDK (API) HTML based API
VMD (Video Motion Detection) User set 5 ROI (Region of Interest), 10 Step Sensitivity
Alarm Trigger VMD, External Alarm Input
Alarm Event E-mail notification, FTP Uploading, Alarm out
POWER
Power Source Triple Power - 12VDC 1A / 24VAC (50Hz/60Hz) 500mA, PoE Class 2 (IEEE 802.3af compliant)
Power Consumption 386mA @ DC12V, Max 4.8W PoE : 100mA @ DC48V, Max 4.8W
OTHER SPECIFICATIONS
Micro SD Card Micro SDHC card compatible - SanDisk, Transcend, Kingston,Toshiba: 1G, 2G, 4G, 8G,16G, 32G
External I/O Terminals Alarm In x1, Alarm Out x1, Audio In x1, Audio Out x1
Operating Temperature/Humidity 14ºF ~ 122ºF / -10ºC ~ 50ºC (use with iPak outdoor housing for extended temperature range)
Humidity less than 90%, non-condensing
Materials Aluminum Die Casting
Weight .5 lbs. / 250g
Dimensions (W x H x D) 2.5â€
Joe
Digital Zoom 8x
AGC Yes
ANALOG
NETWORK
Image Compression
Resolution
320 x 240
POWER
Ganz ZN-C1M on internet
Hey kingofkya here ya go. This is one of my Ganz ZN-C1M Cameras.
http://70.133.141.121
user name: ADMIN ( case sensitive )
passwd: 1234
Hoping you can help me solve this. I think zm would work well with what I’m trying to do.
Thanks for your help.
passwd: 1234
