GANZ ZN-C1M Camera and Zoneminder 1.24.2
joepeterson
Post by joepeterson »
OK! I hope I’m putting this in the right place.
I have about 25 Ganz ZN-C1M Cameras on site and working.
I would like to get them working on my ZM system if that's possible. If anyone has any experience with these type of cameras and ZM I would be forever grateful for some help on getting set up.
Thanks for your time and reading my post.
Joe Peterson
kingofkya
Post by kingofkya »
Do you have any specs on the cameras? Also if not are you able to put one on the Internet so we can see if it is compatible.
joepeterson
Camera Specs.
Here are the specs. for the GANZ ZN-C1M Camera.
I will do some port forwarding and get one of them on the net.
Thanks for your help and will get back to you just as soon as I have you one to look at..
Joe
Sensor 1/2.5" Progressive Scan CMOS
Max. Resolution 1080p 720p VGA
Effective Pixels 2560 (H) x 1920 (V)
White Balance ATW / MANUAL (PRESET)
Digital Zoom 8x
AGC Yes
BLC (Backlight Compensation) Yes
Iris Manual / DC Auto Iris
Shutter Speed 4, 1/10, 1/12.5, 1/15, 1/20, 1/25, 1/30, 1/50, 1/60, 1/100, 1/120, 1/240, 1/480, 1/960, 1/1024, 1/2000 s
Lens Mount CS/C (Adapter)
Day/Night Performance IR Cut Filter, True Day/Night
Dynamic Range 70.1 dB
Min. illumination Color: 0.7 lux (F1.2, 30IRE), B/W: 0.08 lux (F1.2, Slow Shutter ON, 30IRE)
ANALOG
Video Signal NTSC/PAL selectable
Monitor Output Composite Output (BNC), 75 ohm 1Vpp
Scanning Frequency NTSC: (H) 15.734 kHz, (V) 59.94 Hz / PAL: (H) 15.625 kHz, (V) 50 Hz
Resolution Horizontal: 600 TVL or more / Vertical: 350 TVL or more
NETWORK
Network 10BASE-T, 100BASE-TX, RJ45
Image Compression
H.264: - Main Profile, Simple / Advanced Mode, Base Profile (D1 resolution only)
MJPEG - 2nd stream only
Resolution
1920 x 1080, 1280 x 720, 1280 x 720 (Wide),
1280 x 1024, 1024 x 768, 640 x 480,
320 x 240
640 x 480, 320 x 240
Protocol IPv4/6, HTTP, HTTPS, SMTP, UPnP, DNS, Dynamic DNS, NTP, RTSP, RTP, TCP, UDP, IGMP, RTCP, ICMP, DHCP, ARP
Frame Rate 2.5 fps ~ 30 fps
Web Browser Internet Explorer 7.0 or above, PDA / Smart phone
Security Password Protection, HTTPS, IP Addressing Filtering
SDK (API) HTML based API
VMD (Video Motion Detection) User set 5 ROI (Region of Interest), 10 Step Sensitivity
Alarm Trigger VMD, External Alarm Input
Alarm Event E-mail notification, FTP Uploading, Alarm out
POWER
Power Source Triple Power - 12VDC 1A / 24VAC (50Hz/60Hz) 500mA, PoE Class 2 (IEEE 802.3af compliant)
Power Consumption 386mA @ DC12V, Max 4.8W PoE : 100mA @ DC48V, Max 4.8W
OTHER SPECIFICATIONS
Micro SD Card Micro SDHC card compatible - SanDisk, Transcend, Kingston,Toshiba: 1G, 2G, 4G, 8G,16G, 32G
External I/O Terminals Alarm In x1, Alarm Out x1, Audio In x1, Audio Out x1
Operating Temperature/Humidity 14ºF ~ 122ºF / -10ºC ~ 50ºC (use with iPak outdoor housing for extended temperature range)
Humidity less than 90%, non-condensing
Materials Aluminum Die Casting
Weight .5 lbs. / 250g
Dimensions (W x H x D) 2.5â€
joepeterson
Ganz ZN-C1M on internet
Hey kingofkya here ya go. This is one of my Ganz ZN-C1M Cameras.
http://70.133.141.121
user name: ADMIN ( case sensitive )
passwd: 1234
Hoping you can help me solve this. I think zm would work well with what I’m trying to do.
Thanks for your help.
kingofkya
Post by kingofkya »
Looking at the camera now.
The activeX has already crashed IE.
What else is new huh.
EDIT:
I think i need port 554 forwarded as well.
