Native android interface
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
mrd
Post by mrd » Sat Jan 16, 2010 3:09 pm
Has anyone figured out how to get live streams on an android device yet?
Or at least found a way to support 3gp streaming through zm?
MRD
Ben
Post by Ben » Sat Jan 29, 2011 11:17 am
Try IPCAMviewer. You can find it in the store... You can select zoneminder in the program.
punch-card
Tiny Cam Monitor
Post by punch-card » Sun Jan 30, 2011 7:39 pm
Try "Tiny Cam Monitor" it works pretty good, the secret to figure out which cam you need to connect to is look at the URL for the number from the main zm page when you mouse over each camera. Point to the Camera name, and look at the mid parameter of the URL.
Check out this thread http://www.zoneminder.com/forums/viewto ... highlight=
Best Regards
Mike
lazerusrm
Post by lazerusrm » Thu Feb 10, 2011 5:07 am
Tiny Cam Monitor just released a new version with native support.
when adding in the server, just put in the ip address of the server, and under camera type, select zone minder, then in the advanced settings you can set the stream number.
-Brad
PTZ functions are working as well. i have tested them.
siddle81
Re: Native android interface
Post by siddle81 » Wed Jul 06, 2011 10:04 am
Android Native Development Using the Android Open Source Project, I mentioned that there are now two primary sets of tools that can be used to develop Android applications that include native C/C++ native code. The original, and still unsupported way, is to leverage the tools built into the Android Open Source Project to build Android applications.
jameswilson
Post by jameswilson » Fri Aug 12, 2011 8:04 pm
as android supports flash id suggest flash streaming. I did knock up a proof on concept that used the full screen movie player to view a stream. Ill look into it some more. But i too use the ipcam viewer app.
James Wilson
