Has anyone figured out how to get live streams on an android device yet?
Or at least found a way to support 3gp streaming through zm?
Native android interface
- punch-card
Tiny Cam Monitor
Try "Tiny Cam Monitor" it works pretty good, the secret to figure out which cam you need to connect to is look at the URL for the number from the main zm page when you mouse over each camera. Point to the Camera name, and look at the mid parameter of the URL.
Check out this thread http://www.zoneminder.com/forums/viewto ... highlight=
Best Regards
Mike
Mike
Re: Native android interface
Android Native Development Using the Android Open Source Project, I mentioned that there are now two primary sets of tools that can be used to develop Android applications that include native C/C++ native code. The original, and still unsupported way, is to leverage the tools built into the Android Open Source Project to build Android applications.
- Contact:
as android supports flash id suggest flash streaming. I did knock up a proof on concept that used the full screen movie player to view a stream. Ill look into it some more. But i too use the ipcam viewer app.
James Wilson
Users browsing this forum: No registered users and 0 guests
