add an extra hard drive in zoneminder
titof2375
Post by titof2375 »
hello, I would like to add a hard disk on the zoneminder lxc, I would like to know if I have to modify files for detection
tsp84
Re: add an extra hard drive in zoneminder
Post by tsp84 »
Yes, in the storage tab of Options ->
Screenshot from 2021-03-21 12-02-07.png (408.91 KiB) Viewed 10146 times
titof2375
Post by titof2375 »
what is there to do?
tsp84
Post by tsp84 »
You setup a new storage with the /path/to/new/storage
tsp84
Post by tsp84 »
Dont forget to change the "Storage" on your monitor feeds to point to your new hard drive once you have it set up in zm.
Screenshot from 2021-03-21 15-35-13.png (417.89 KiB) Viewed 10130 times
burger
Post by burger »
https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
Don't forget to make a new filter for purgewhenfull on the storage area.
fastest way to test streams:
titof2375
Post by titof2375 »
hello, it was checked in origin
tsp84
Post by tsp84 »
I dont understand the last reply. As long as you have that hard drive properly setup and mounted into the docker container, you should only need to point ZM to the /path/to/new/hard/drive, make sure it is "Enabled" and then change the "Storage" options in your monitor feeds to point towards your new hard drive/mount point.
titof2375
Post by titof2375 »
for info I am not on my proxmox docker, and nothing goes on the hard drive.
tsp84
Post by tsp84 »
  • First click the yellow circled area in CONSOLE view (ip or /path/ to camera)
Screenshot from 2021-03-23 04-59-31.png (507.75 KiB) Viewed 10051 times
  • Then go to "Storage" tab circled in green and then click the drop down menu circled in blue and select your new hard drive
Screenshot from 2021-03-23 05-03-24.png (424.57 KiB) Viewed 10051 times
titof2375
Post by titof2375 »
yes, yes how is it already
tsp84
Post by tsp84 »
Then the events that happen now will start to save to your new hard drive
titof2375
Post by titof2375 »
No, it's been like that since yesterday and nothing on the new record.
tsp84
Post by tsp84 »
Check the log. See if the permissions are causing errors. See if user www-data can write to the /path/to/hdd
titof2375
Post by titof2375 »
I solved the problem otherwise, I moved zoneminder directly to the hard drive of 1 terra, like that no more storage problem.
