add an extra hard drive in zoneminder
hello, I would like to add a hard disk on the zoneminder lxc, I would like to know if I have to modify files for detection
Re: add an extra hard drive in zoneminder
Yes, in the storage tab of Options ->
- Screenshot from 2021-03-21 12-02-07.png (408.91 KiB) Viewed 10145 times
what is there to do?
You setup a new storage with the /path/to/new/storage
Dont forget to change the "Storage" on your monitor feeds to point to your new hard drive once you have it set up in zm.
- Screenshot from 2021-03-21 15-35-13.png (417.89 KiB) Viewed 10129 times
https://wiki.zoneminder.com/Using_a_ded ... Hard_Drive
Don't forget to make a new filter for purgewhenfull on the storage area.
fastest way to test streams:
hello, it was checked in origin
I dont understand the last reply. As long as you have that hard drive properly setup and mounted into the docker container, you should only need to point ZM to the /path/to/new/hard/drive, make sure it is "Enabled" and then change the "Storage" options in your monitor feeds to point towards your new hard drive/mount point.
for info I am not on my proxmox docker, and nothing goes on the hard drive.
- First click the yellow circled area in CONSOLE view (ip or /path/ to camera)
- Then go to "Storage" tab circled in green and then click the drop down menu circled in blue and select your new hard drive
yes, yes how is it already
Then the events that happen now will start to save to your new hard drive
No, it's been like that since yesterday and nothing on the new record.
Check the log. See if the permissions are causing errors. See if user www-data can write to the /path/to/hdd
I solved the problem otherwise, I moved zoneminder directly to the hard drive of 1 terra, like that no more storage problem.
