Page 1 of 1
api doesn't work on raspberry pi 3 with buster OS
Posted: Wed Aug 05, 2020 7:20 am
by david1234
Hello ,
I'm running zoneminder V1.34.16 on pi Buster OS.
everything is working with the zoneminder (record 3 cameras all the time ,with sound - work great!)
now I'm trying to use API ,
I have done what it said in the guide
AUTH_RELAY is set to hashed
A valid AUTH_HASH_SECRET is provided (not empty)
AUTH_HASH_IPS is disabled
OPT_USE_APIS is enabled
OPT_USE_GOOG_RECAPTCHA is disabled
have try with and without OPT_USE_AUTH (with password and without password)
no metter what I do
I get error
curl -XPOST -d "user=David&pass=Davidpass" http://10.0.0.105/zm/api/host/login.json
{"name":"Not Found","message":"Not Found","url":"\/api\/zm\/api\/host\/login.json"}
pi@raspberrypi:~$
I have restart the zoneminder service
reboot the pi
still not working
what is missing?
Thanks ,
Re: api doesn't work on raspberry pi 3 with buster OS
Posted: Sun Aug 09, 2020 6:47 am
by david1234
anything?
cant be the only one....
Thanks,
Posted: Sun Aug 09, 2020 12:13 pm
by bbunge
What instructions did you use to install Zoneminder?
Or did you use the pre-built image?
Posted: Mon Aug 10, 2020 1:27 pm
by david1234
pre-build image from here
https://zmrepo.zoneminder.com/
Posted: Sun Aug 23, 2020 7:03 am
by david1234
anyone?
Posted: Sun Nov 08, 2020 8:23 am
by david1234
can someone help \guide maybe ?
I really love working with zoneminder and the API option could make this program 100% good for my needed
