api doesn't work on raspberry pi 3 with buster OS
david1234
Post by david1234 »
Hello ,
I'm running zoneminder V1.34.16 on pi Buster OS.
everything is working with the zoneminder (record 3 cameras all the time ,with sound - work great!)
now I'm trying to use API ,
I have done what it said in the guide
AUTH_RELAY is set to hashed
A valid AUTH_HASH_SECRET is provided (not empty)
AUTH_HASH_IPS is disabled
OPT_USE_APIS is enabled
OPT_USE_GOOG_RECAPTCHA is disabled
have try with and without OPT_USE_AUTH (with password and without password)
no metter what I do
I get error
curl -XPOST -d "user=David&pass=Davidpass" http://10.0.0.105/zm/api/host/login.json
{"name":"Not Found","message":"Not Found","url":"\/api\/zm\/api\/host\/login.json"}
pi@raspberrypi:~$
I have restart the zoneminder service
reboot the pi
still not working
what is missing?
Thanks ,
david1234
Re: api doesn't work on raspberry pi 3 with buster OS
Post by david1234 »
anything?
cant be the only one....
Thanks,
What instructions did you use to install Zoneminder?
Or did you use the pre-built image?
david1234
Post by david1234 »
pre-build image from here
https://zmrepo.zoneminder.com/
david1234
Post by david1234 »
anyone?
david1234
Post by david1234 »
can someone help \guide maybe ?
I really love working with zoneminder and the API option could make this program 100% good for my needed
bootybymayo
Post by bootybymayo »
I also encountered issues getting the API to work on a raspberry pi running buster.
What fixed it for me was following these steps here:
viewtopic.php?t=28435#p111193
And then changing this file mentioned here:
https://github.com/ZoneMinder/zoneminde ... -532723937
The actual file I changed ended up being usr/share/zoneminder/www/api/app/Config/core.php as opposed to Configure/core.php mentioned in the post.
After a restart my API seems to be working.
