API not working after install on fresh Buster system
jake1164
Post by jake1164 »
I did a fresh Debian 10 (Buster) install following the posted instructions.
Upon restarting apache and before doing anything else ZM is running, logs are green, however when you navigate to :
http://ip/zm/api/host/getVersion.json results in a Not Found page.
The API directory (/usr/share/zoneminder/www/api) has the following files / folders:
app build.properties build.xml composer.json CONTRIBUTING.md index.php lib README.md
Note that the host folder is missing.
Navigating to http://ip/zm/api/ results in the following CakePHP error:
URL rewriting is not properly configured on your server. 1) Help me configure it 2) I don't / can't use URL rewriting
I followed the instructions a second time on a fresh VM and had the same results.
I have found a few fragments of other issues with buster api's but no definitive resolution.
Re: API not working after install on fresh Buster system
I must admit that I did not check the API as I seldom use anything other than a web browser. Will try to find time to load up Debian again and see what I can find.
JoshZ17
Post by JoshZ17 »
I'm having the same issue. Fresh install of Buster.
Looks like all the files installed with correct permissions. Cake reports rewrite not working. Looking into Apache config. Seems sim to issues we had with Ubuntu 17.10.
Will continue in the morning...old guys need sleep, too.
girkers
Post by girkers »
I spent a day trying buster without success and I ended up using CentOS instead.
Girkers
logicos94
Post by logicos94 »
Some issues too in https/http support:
I noticed this:
var monitorUrl = 'https://zm.eez.fr:80/zm/index.php';
My server is behind a "nginx/proxy" with "https" protocol.
But local http Apache server listen on port "80" with "http" protocol.
"SetEnv HTTPS on" is present in my "VirtualHost" configuration.
":80" is irrelevent here.
If I remove this , It's work like expected.
Regards,
logicos94 wrote: Sat Jul 13, 2019 10:53 am Hi,
I noticed this:
Regards,
But does your api work?
There are some .htaccess files missing from the /usr/share/zoneminder/api directories. This may be the key to the API not working. May take me some time to figure this out as Saturday chores take preference...
sammyke007
Post by sammyke007 »
Same here, fresh Debian 10 (Buster) installation and API's not working.
Chimaera
Post by Chimaera »
bbunge wrote: Sat Jul 13, 2019 1:31 pm There are some .htaccess files missing from the /usr/share/zoneminder/api directories. This may be the key to the API not working. May take me some time to figure this out as Saturday chores take preference...
This is the answer, you need to add the following code to .htaccess in 3 places
/usr/share/zoneminder/www/api/app
/usr/share/zoneminder/www/api/app/webroot
<IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteRule ^ index.php [L]
    RewriteBase /zm/api
</IfModule>
sammyke007
Tnx Chimaera! ZMNinja is connected!
Zoneminder + ZMNinja working fine now on an old Dell Optiplex 780 SFF running Debian 10!
jake1164
Post by jake1164 »
Thanks! Now I can get my wife off my back about how I broke the cameras. :)
david1234
Post by david1234 »
I have the same problem using v 1.34
where do I need to add the code part?
do I need to create .htaccess file?
and then write into it the code?
this is what I have in this library
pi@raspberrypi:~$ ls -lstra /usr/share/zoneminder/www/api/app/webroot/
total 28
4 -rw-r--r--  1 root root 3006 Jun  6 18:07 test.php
4 -rw-r--r--  1 root root 3170 Jun  6 18:07 index.php
4 -rw-r--r--  1 root root  372 Jun  6 18:07 favicon.ico
4 drwxr-xr-x  2 root root 4096 Jun 18 13:38 img
4 drwxr-xr-x  2 root root 4096 Jun 18 13:38 css
4 drwxr-xr-x 10 root root 4096 Jun 18 13:38 ..
4 drwxr-xr-x  4 root root 4096 Jun 18 13:38 .
can you exaplin what did you do ?
Thanks ,
martinjr85
Post by martinjr85 »
Chimaera wrote: Mon Jul 15, 2019 11:28 am
    RewriteEngine On
    RewriteBase /zm/api
</IfModule>
Thanks Chimaera! This worked on my Pi 4 running Zoneminder 1.32.3 for Raspbian
david1234
Post by david1234 »
where are the
.htaccess
files?
I can't see them
when I searc them I get empty response
pi@raspberrypi:~ $ sudo find /usr/share/zoneminder/ -name .htaccess
pi@raspberrypi:~ $
Thanks ,
