filter problem
unnilennium
filter problem
Post by unnilennium » Sun Jun 03, 2007 8:06 pm
since update from 1.22.2 to 1.22.3 filter do not work : so no auto purge and now my disk is 100% full !
here is the error when i try to execute the filter purge :
Unknown column 'Background' in 'field list'
What is this ?
how can i resolve this ?
I should add that i already do this but no chnage :
http://www.zoneminder.com/wiki/index.php/1.22.3_Patches
JPP
unnilennium
Post by unnilennium » Sun Jun 03, 2007 8:44 pm
in zm_actions.php
line 211
I changed
, Background = '$background' ");
to
");#, Background = '$background' ");
and it works for the moment ...
is this a problem during sql update ?
IDo this colom must be created ?
JPP
cordel
Post by cordel » Sun Jun 03, 2007 11:13 pm
Yes, that colum must be created and should have when you updated the database. The filter will not run otherwise.
unnilennium
Post by unnilennium » Mon Jun 04, 2007 7:09 am
et voila
I execute the good commannd to update the database and everything is good
# zmupdate.pl --version=1.22.2 -u root -p *******
Users browsing this forum: No registered users and 0 guests
