Hi!
Regarding the timestamp, some questions:
1. Can the date format in the Timestamp Label, changed in a way so that it displays the long date? Like 2007-march-27 instead of 07/03/27.
2. Can the timestamp background made translucent? The text color changed?
3. How about increasing the image height (canvas) with the height of the timestamp and saved like that? Because the picture information behind the timestamp is lost now. And then, eventually resize the image back to the same resolution. A little wide-screen effect would appear, but that wouldn't matter, the contents of the full image would perhaps be more important than the exact aspect ratio.
Timestamp Label Format
The timestamp label format follows the *nix 'date' format (see man date). Default is: %%s - %y/%m/%d %H:%M:%S
For a format of 2007-march-27, (with the time of date the same), use:
%%s - %Y-%B-%d %H:%M:%S
Check out the man page if you want to mess with it further, check under subsection FORMAT.
As for transparency and text color, I see no controls for alpha blending nor text color changing, but maybe if you send ZM a box of cookies, he'll add it for you.
Might be a useful feature to squish the image a bit to fit a timestamp above (or below) the image, to prevent blocking out part of the video. For now, you could play with the timestamp label x/y values to at least move the timestamp to a place in your video that has no importance (like high on a wall or something).
Thanks!
Tip/Suggestion: Perhaps filling the time/date/capture info in the jpeg's EXIF tag, would also be a good tip. Also filling the generated mpeg, avi video's tags with the same info. As most image viewers and video players can display this info, either superimposed on the picture or in an additional panel.
This way the user can opt for each image to have or not the info displayed, after capture.
Man says "No manual entry for date". Found it in google anyway.ammaross wrote:The timestamp label format follows the *nix 'date' format (see man date). Default is: %%s - %y/%m/%d %H:%M:%S
Question: is it safe to change the system's locale, to have eg. hungarian month names? Would this affect ZM's functionality?
Well, that's the problem. If the system returns the date in some sort that ZM doesn't understand, database entries may get messed up...ammaross wrote:It should not affect ZM, since it just asks the system for the date string, rather than trying to formulate its own.Question: is it safe to change the system's locale, to have eg. hungarian month names? Would this affect ZM's functionality?
I guess the best way would be to try with a test system. MySQL should be using the same date interpreting call as PHP (and thus ZM) so both should change over when you switch locales, but I've been wrong before.robi wrote:Well, that's the problem. If the system returns the date in some sort that ZM doesn't understand, database entries may get messed up...
- zoneminder
- Site Admin
- Contact:
http://owl.phy.queensu.ca/~phil/exiftool/zoneminder wrote:Adding the timings to the jpeg headers is a good idea. If I can figure out how to do it
