latest ffmpeg drops INT64_C
bigb135
Post by bigb135 »
First of all, great work.. been using ZM for a few months now and it is good stuff!
Normally I lurk 100%, but I amazingly have something to contribute, so you made me post.
In late febuary ffmpeg dropped INT64_C from their include.h, so I had to add the follwing line to zm_mpeg.h before I built from source:
#define INT64_C
I grabbed the ffmpeg from CVS today, but I think the change was comitted about Feb 25th.
Anyways, now I have streaming support..
On an aside, how about the ability to specify ffmpeg vs jpg encoded streams via the bandwith settings? I would like to stream ffmpeg via internet (medium bandwith), but have the real-time lan viewing for jpg streams (high bandwith).
Thanks!
SyRenity
Post by SyRenity »
Hi.
The official solution from FFMPEG is to add the following line before any ffmpeg headers inclusion:
#define __STDC_CONSTANT_MACROS
I think a patch should be prepared.
zoneminder
Site Admin
Post by zoneminder »
Thanks for this. The next trick is to find out exactly when this change went in so I can conditionally add the define for the right versions.
Phil
SyRenity
Post by SyRenity »
Hi.
I don't think it was numbered any specifically, but AFAIK it's a pretty harmless definition.
