system camera to check people
collinm
Post by collinm » Tue Nov 07, 2006 2:34 am
hi
i want to build a system with 16 cam (6fps by camera
now blueberry have a new card
PV-183 - 8 port video, 8 port audio capture card
i would like to have tips.....
2 solution
#1
does i should buy 2 PV-183 and connect 16 cam...
i imagine every bnc, rca cam can be connected to this kind of card?
#2
buy 16 ip camera like axis 206
does the both solution with use same cpu, memory quantity?
thanks
zoneminder
Site Admin
Post by zoneminder » Tue Nov 07, 2006 4:20 pm
You should be able to connect pretty much all analogue cams to a PVR card. Using IP cams will increase the load on your ZM box (and your network) as they have to decode jpegs input as well as encode the images. The memory and disk etc could be the same though.
Phil
PRDR
Post by PRDR » Sun Nov 26, 2006 11:27 pm
collinm:
It seems you are in luck:
http://store.bluecherry.net/16_port_vid ... 183_16.htm
16 port video 240FPS & 8 port audio capture card, and it even advertises ZoneMinder support...
zoneminder
Site Admin
Post by zoneminder » Mon Nov 27, 2006 1:59 pm
The Shop page gives details on how to claim a discount from BlueCherry. Also you can use the affiliate link on that page to help ZM development.
Phil
calixto
Post by calixto » Mon Nov 27, 2006 8:55 pm
This looks like a good option,
may I use two of the PV-183?
thanks
curtishall
Post by curtishall » Wed Nov 29, 2006 3:59 am
We haven't tried two of the PV-183's yet in one machine. I wouldn't see this as a problem, as the bttv module is pretty sane about loading chips from different cards
Direct link: http://store.bluecherry.net/ProductDeta ... 6&Click=51
(Includes the affiliate code to help Zoneminder)
Curtis Hall (curt@bluecherry.net)
Bluecherry - www.bluecherry.net
calixto wrote:This looks like a good option,
thanks
jamescollings
Post by jamescollings » Wed Nov 29, 2006 9:50 am
Does anyone know where I can get the PV-xxx range of cards in the UK.. or do BlueCherry ship across the "Pond".
I looked on their website, but couldn't see a "feedback" form where I could ask them.
zoneminder
Site Admin
Post by zoneminder » Wed Nov 29, 2006 12:37 pm
They do ship here, as I have had stuff off them. I can't remember the P&P cost though but if you drop Curtis (just up the thread) a mail or pm he will be able to tell you.
Phil
jamescollings
Post by jamescollings » Wed Nov 29, 2006 2:53 pm
Just ordered (using the Zoneminder coupon)...
The next stage in my zoneminder set-up is a courier visit away :lol:
skow
Post by skow » Wed Feb 14, 2007 10:30 pm
How did things go with the pv-183? I'm curious to hear some usage stories on this card...
Thanks!
chalo
Post by chalo » Thu Feb 15, 2007 7:26 pm
Hi!
I recently purchased the PV183-16. The card works as expected and the guys at bluecherry are very helpful, but bear in mind something: the card has 8 chips, so you will be able to get 240fps ONLY if you use 8 cameras. If you use 2 cameras per chip, expect 5fps at the most, that´s what I get. 5fps is perfect for most needs.
I am planning on trying placing 2 of these cards, with 32 cams altogether, on a P4 dual 2G Ram and aprox 400G disk... first I will see how one card does on my current P4 (not dual) 512meg... to see if trying the other setup makes sense... ALL cameras will have modetect, but more than half of them will only record events about 15-30 min a day. The rest will have motion about 6hrs/day. If I do the test I will post... if anyone else has tried 2 of these cards on one system, please reply!
Regards,
Gonzalo
abroz
Post by abroz » Thu Feb 15, 2007 9:54 pm
Hi!
Not the same card, but close - PV183-8
I've set it up to run at 10fps in normal times and at 15fps at alarms.
And it works like charm. About resolutions:
2 cameras are RGB565 at 576x432 and 2 other cameras are RGB565 at 384x288.
Don't know why, but I have a problem with RGB24 on them, and also had "problem" with bttv card autodetect - it is detected as unknown.
So, I forced it as PV150. Tried to get support from bluecherry but my ticket is still open (and has been for a while)...
But all-in-all - this one rocks.
Regards,
Aj
curtishall
Post by curtishall » Mon Feb 19, 2007 3:35 am
If you want to give me your ticket number I'll lookup the ticket. Managing tickets has proven to be interesting
abroz wrote:Hi!
Regards,
Aj
Curtis Hall
Bluecherry
www.bluecherrydvr.com
Lee Sharp
Post by Lee Sharp » Tue Jun 12, 2007 11:49 pm
I just got a couple of PV-155 16 port cards from the. The e-mail support is fantastic! And yes, the cards work well after the appropriate modprobe line is added. This is only a 120 fpm card. Yes, the frame rate split can be less than intuitive.
Users browsing this forum: No registered users and 14 guests
