A guide to managing system load with ZoneMinder
Moderator: zoneminder
Flash_
Postby Flash_ » Fri Oct 27, 2006 8:23 pm
(Written with IP Cameras in mind)
Why do ZM need so much grunt?
Think what Zoneminder is actually doing. In modect mode ZM is:
1. Fetching a jpeg from the camera. (Either in single part or multipart stream)
2. Decoding the jpeg image.
3. Comparing the zoned selections to the previous image or images and applying rules.
4. If in alarm state, writing that image to the disk and updating the mysql database.
How do I know if my computer is overloaded?
My load is too high, how can I reduce it?
Change the jpeg libraries. In most distributions Linux uses standard jpeg libraries which although fine for most things, don't use the MMX functions in nearly all modern processors. Check whether your cpu supports mmx by running "cpuid |grep MMX" which should give you a line or two along the lines of "MMX instructions". If so, give the libs a try. Most people report their load halves simply by using these libs. http://www.zoneminder.com/forums/viewtopic.php?t=6419 gives more info. Nobody's posted there to say it broke their system... Yet.
More expensive options:
What about disks and bandwidth?
Disk and Bandwidth calculators are referenced on the Zoneminder wiki here: http://www.zoneminder.com/wiki/index.ph ... _for_ZM.3F
cordel
Postby cordel » Fri Oct 27, 2006 11:11 pm
Thanks for this Flash_ :D
And Thank you for taking the time to post it.
Cheers,
Corey
jameswilson
Postby jameswilson » Fri Oct 27, 2006 11:36 pm
yes very useful. perhaps you would like it on the wiki!
Great advice there
James Wilson
Flash_
Postby Flash_ » Sat Oct 28, 2006 7:26 am
Thanks and thanks. And it's wiki'd already - my first wiki!
SlovakJoe
Disk IO
Postby SlovakJoe » Mon Mar 17, 2008 9:49 pm
Disk IO has been my main bottleneck. In the test server I have running, anytime I go to delete a number of events, the deletion causes the system load to increase tremendously. During normal recording conditions the RAM is underutilized, CPU is underutilized, and the recording works smoothly. So far so good. But when anywhere from 5 to 50 GB worth of events are deleted, the system load jumps from say .5 up to 4. At that point Apache drops requests and I can no longer view the main ZM console window. The Apache problem is likely due to this being a test system and using old hardware.
The disk IO performance when deleting and recording at the same time is causing a significant spike in system load. This isn't a surprise, but I'm wondering if other people have problems like this as well? It's to be expected when you have all your events on a single IDE drive. When I move this to production, the production server will most likely use RAID 0 (or 5) or JBOD which will be of great help.
coke
Disk speed
Postby coke » Tue Mar 18, 2008 12:23 am
I'm pretty new at the ZoneMinder game, but in my non-scientific experience so far, RAID 0 is worlds better than one drive. My initial tests set to record all on one drive took ages to delete old events, and pegged the CPU. Reformatted the system (2 320gb drives) into 1 RAID 0 640GB, and it's running like a champ, deleting piles of dirs (more than rm -r can usually handle in one swipe) fairly instantly.
May or may not have something to do with it now being Reiserfs instead of ext3.
SlovakJoe
Postby SlovakJoe » Tue Mar 18, 2008 6:11 am
Thanks for the update Coke. Like I said, the performance problem is to be expected given my hardware setup. It has nothing to do with ZoneMinder. And as for deleting all those files, after a certain point, you can't even use "rm -rf" anymore. You have to use "find" and pipe the output to "rm". Fortunately, ZM takes care of this all.
Either way, I'd never use a single drive in a production system unless it only had a couple of cameras.
In addition to JBOD for disk spanning, I'm considering switching from Ubuntu to Fedora for the built in LVM support. With LVM you can take multiple disks of different size and group them together into 1 logical drive. This would make life a lot easier for those of us with handfuls of spare 120 and 160 gig drives.
zoneminder
Site Admin
Postby zoneminder » Tue Mar 18, 2008 8:55 pm
If you use the original flat filesystem then deleting files from directories with tens of thousands of events in will be slow. The deep filesystem available in 1.23.x is much quicker as no directory has more than a handful of other directories in.
Phil
SlovakJoe
Postby SlovakJoe » Thu Mar 20, 2008 2:58 am
zoneminder wrote:If you use the original flat filesystem then deleting files from directories with tens of thousands of events in will be slow. The deep filesystem available in 1.23.x is much quicker as no directory has more than a handful of other directories in.
When I first read about that feature I was very excited. However, the documentation states that this feature is not ready for production. My test server is running ZM 1.23.1 and in the configuration window, the help for that feature states "Be warned: deep storage should be considered in beta for now, if you value your data do not select it.". Maybe 1.23.2 has fixed this?
If it is in fact a stable feature, then I'll switch to that and compare the performance of a single IDE drive using deep directories VS RAID 0 drives using the flat file structure.
Either way, RAID 0 should eliminate any serious disk IO issues.
Lee Sharp
Postby Lee Sharp » Sun Mar 30, 2008 6:35 pm
Consider the filesystem as well. The Live CDs for ZM and most other distributions use ext3 by default. While robust, ext3 is NOT a performance filesystem. I have been thinking a while about benchmarking a few filesystems with ZM to see the difference. Most of them have better delete performance than ext3.
sajithvk
Large scale deployment
Postby sajithvk » Thu Apr 24, 2008 3:29 am
I have been using zoneminder for a few months on test basis, and it works perfectly for my requirements, including motion detection, recording etc. Currently, we have a requirement to implement large scale surveillance, covering around 70 IP cameras, each at 640x480 resolution (some PTZ, some fixed). Is it advisable to use zm for this situation? I feel everything ok, but the shared memory required may be a big issue.......
Has anyone tested zm on 50+ ip cameras? Or can any one give me tips on how to go about it?
Return to “ZoneMinder Hints & Tips”
Users browsing this forum: No registered users and 0 guests
