System is running 7 Axis IP cameras. Six of these are on Modect and recording events at 640x480 greyscale @ 3-10fps.
Those same six are ALSO on Record, 320x240 greyscale @ 2fps since Modect sometimes fails to trigger reliably, and having full stream helps to narrow down the reason.
One camera is on Monitor only, no recording.
Two capture streams from each camera, and as you can see, it all works fine.
Hardware is an Athlon64 3200 running at 2ghz, 1.5Gb of RAM and a single 200g sata drive dedicated for the footage.
Debian unstable, server used for other office tasks.
[quote]
top - 09:44:18 up 1 day, 23:55, 2 users, load average: 0.74, 0.73, 0.33
Tasks: 141 total, 2 running, 139 sleeping, 0 stopped, 0 zombie
Cpu(s): 34.8% us, 1.7% sy, 0.0% ni, 61.9% id, 0.3% wa, 0.0% hi, 1.3% si
Mem: 1556496k total, 1518204k used, 38292k free, 347332k buffers
Swap: 2465936k total, 0k used, 2465936k free, 417412k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3328 www-data 15 0 115m 21m 13m S 3.3 1.4 0:10.98 zmc
3300 www-data 15 0 110m 15m 13m S 2.0 1.0 0:05.98 zma
3316 www-data 15 0 110m 15m 13m S 2.0 1.0 0:06.22 zma
3332 www-data 15 0 110m 15m 13m S 2.0 1.0 0:06.20 zma
3336 www-data 15 0 110m 15m 13m S 2.0 1.1 0:06.37 zmc
3344 www-data 15 0 110m 15m 13m S 2.0 1.0 0:06.03 zmc
3296 www-data 15 0 110m 15m 13m S 1.7 1.0 0:06.27 zmc
3304 www-data 15 0 110m 15m 13m S 1.7 1.0 0:06.01 zmc
3308 www-data 15 0 110m 15m 13m S 1.7 1.0 0:06.02 zma
3312 www-data 15 0 110m 15m 13m S 1.7 1.0 0:06.16 zmc
3320 www-data 15 0 110m 16m 13m S 1.7 1.1 0:06.29 zmc
3324 www-data 15 0 110m 15m 13m S 1.7 1.0 0:06.22 zma
3340 www-data 15 0 110m 15m 13m S 1.7 1.0 0:06.17 zma
3376 www-data 15 0 100m 5716 4824 S 1.0 0.4 0:02.93 zma
3360 www-data 15 0 100m 5712 4824 S 0.7 0.4 0:02.12 zma
3368 www-data 15 0 100m 5716 4824 S 0.7 0.4 0:02.18 zma
3372 www-data 15 0 101m 7040 4860 S 0.7 0.5 0:02.04 zmc
3384 www-data 15 0 100m 5712 4824 S 0.7 0.4 0:02.13 zma
3348 www-data 16 0 100m 6088 4860 S 0.3 0.4 0:00.66 zmc
3352 www-data 15 0 100m 5712 4824 S 0.3 0.4 0:01.12 zma
3364 www-data 15 0 100m 6024 4860 S 0.3 0.4 0:00.97 zmc
3380 www-data 15 0 100m 6044 4860 S 0.3 0.4 0:00.86 zmc
[quote]
Load spikes to 1.2 through 1.7 if modect starts recording activity.
Bandwidth - 100mbit switched lan. Throughput measured at 700-1000 KB/s, about 10% capacity.
Anyone else got some large setups, what sort of things are capable?
