hi, I've Zoneminder 1.22 running in Fedora 4 and when run 'zmpgk.pl start'
all seems Ok. If check 'zmpgk.pl status' returns 'running', but when open URL 'http://192.168.16.7/zm/index.php' in Screen shows Sttoped.
i'd been seeing loggers and the only error i see is this in zmwatch.log:
28/02/06 13:51:07.842332 zmwatch[2294].INF ['zmc -m 1' starting at 06/02/28 13:51:07, pid = 2794] at /usr/local/bin/zmwatch.pl line 118
28/02/06 13:51:17.859365 zmwatch[2294].ERR [Can't get shared memory id '7a6d4001', 1: No existe el fichero o el directorio]
28/02/06 13:51:17.861396 zmwatch[2294].INF [Restarting capture daemon for Base3, shared memory not valid]
28/02/06 13:51:19.536447 zmwatch[2294].INF ['zmc -m 1' started at 06/02/28 13:51:19] at /usr/local/bin/zmwatch.pl line 118
28/02/06 13:51:29.550427 zmwatch[2294].ERR [Can't get shared memory id '7a6d4001', 1: No existe el fichero o el directorio]
28/02/06 13:51:29.552436 zmwatch[2294].INF [Restarting capture daemon for Base3, shared memory not valid]
28/02/06 13:51:31.222029 zmwatch[2294].INF ['zmc -m 1' started at 06/02/28 13:51:31] at /usr/local/bin/zmwatch.pl line 118
28/02/06 13:51:41.235672 zmwatch[2294].ERR [Can't get shared memory id '7a6d4001', 1: No existe el fichero o el directorio]
28/02/06 13:51:41.238314 zmwatch[2294].INF [Restarting capture daemon for Base3, shared memory not valid]
28/02/06 13:51:42.916541 zmwatch[2294].INF ['zmc -m 1' started at 06/02/28 13:51:42] at /usr/local/bin/zmwatch.pl line 118
28/02/06 13:51:52.929846 zmwatch[2294].ERR [Can't get shared memory id '7a6d4001', 1: No existe el fichero o el directorio]
28/02/06 13:51:52.931877 zmwatch[2294].INF [Restarting capture daemon for Base3, shared memory not valid]
somebody can help me?. Apache and Mysql are running.
- zoneminder
- Site Admin
- Contact:
Delete Sock File
will help and kill all ZM processes.
Or try a machine reboot to get rid of all processes of zm. Then start the zm stuff via the zoneminder webpage.
At least for me this worked out.
wolfram
wolfram
wolfram
