Id like to look into getting alarms into and out of zm. Im wondering what everyone uses. Id ideally like an IP solution or a hardwired pci card type input. Id like to be able to use these as triggers for zm and for other things (ie dead monitors) to alarm of movement in set areas via zm4ms or the new linux version when remoted. So basically how you all doing alarms without X10. Or does anyone know of anything close that ican look at and talkto in the linux and windows app. Once i get soemthing working in zm4ms it wont be too hard to add to zm nativly
James
Alarm Inputs
Alarm Inputs
James Wilson
ok mate ill do a search for that too
James Wilson
Here ya go, do ya one better
Here is the manufacturers website http://www.globalcache.com/
It's a pretty niffty little product.
dont suppose you know of any pci based ones too do ya ,mate
James Wilson
related links,
http://www.maxim-ic.com/products/ibutto ... /index.cfm
http://owfs.sourceforge.net/
http://www.hobbytron.com/SensorsandRemotes.html
http://www.z-wavealliance.org/content/modules/Start/
http://www.zigbee.org/en/index.asp
http://www.frazer.net.nz/wrting/wrtprojects.htm
http://www.digi.com/products/embeddedmo ... nectme.jsp
http://www.eesensors.com/websensor.html
http://www.ipenabled.com/
http://www.neteon.net/prod.asp?pc=18&p= ... s%201-Port
just part of collection of my links, based on last few months in-depth analysis on this subject, which has been pretty dynamic during last years, in the midst of the juncture of automation and ubiquitous IP and related services
