Koenzie
Posts: 29 Joined: Mon Dec 12, 2005 8:53 am
Post
by Koenzie » Mon Dec 12, 2005 8:57 am
I've got a little problem with my ZoneMinder install.
I can't view recorded events as a video, i can only see the stills.
This is my config.
Zoneminder 1.21.3
Pentium 4
512MB
300 GB disk
Debian 3.1 r0a
Apache 2
PHP 5
Mysql ... all the normal stuff
There are no special things in the log files
zoneminder
Site Admin
Posts: 5215 Joined: Wed Jul 09, 2003 2:07 pm
Post
by zoneminder » Mon Dec 12, 2005 9:43 am
What platform are you trying to view from? Do you have ffmpeg installed?
Phil
Koenzie
Post
by Koenzie » Mon Dec 12, 2005 9:46 am
I'm trying to view from Windows, using Firefox and IE, both dont work
I have ffmpeg installed and i can view live and recordfed events only stills
zoneminder
Site Admin
Post
by zoneminder » Mon Dec 12, 2005 9:47 am
Do you go to the stills view directly or just get nothing and then click on the Stills link? I assume you have Options->Tools->ZM_CAN_STREAM set to yes or auto?
Phil
Koenzie
Post
by Koenzie » Mon Dec 12, 2005 9:49 am
I go to the stills by clicking stills, when i click a event i first get nothing then i click stills, the option is on auto and i'm not using caram.. because when i use this the effect is still the same, nu recorded video but only stills
zoneminder
Site Admin
Post
by zoneminder » Mon Dec 12, 2005 9:55 am
Do you have Options->Video->ZM_VIDEO_STREAM_METHOD set to jpeg?
Phil
Koenzie
Post
by Koenzie » Mon Dec 12, 2005 9:57 am
zoneminder wrote: Do you have Options->Video->ZM_VIDEO_STREAM_METHOD set to jpeg?
Phil
Yes, it's set to jpeg
zoneminder
Site Admin
Post
by zoneminder » Mon Dec 12, 2005 9:59 am
You won't get anything with IE as it doesn't support mpjpegs. You should with FF though. It might be worth trying with Cambozola just as a test.
Phil
Koenzie
Post
by Koenzie » Mon Dec 12, 2005 10:01 am
zoneminder wrote: You won't get anything with IE as it doesn't support mpjpegs. You should with FF though. It might be worth trying with Cambozola just as a test.
Phil
I tryed Cambozola as a test but i get the same results, no video view
zoneminder
Site Admin
Post
by zoneminder » Mon Dec 12, 2005 10:04 am
Did you have it configured in the Options? If so did it load the applet at all?
I presume there's nothing in the log files (e.g /var/log/messages or /var/log/httpd/error_log) that might indicate a problem with zms?
Phil
Koenzie
Post
by Koenzie » Mon Dec 12, 2005 10:05 am
zoneminder wrote: Did you have it configured in the Options? If so did it load the applet at all?
Phil
The applet loaded, en i can view live video with it, but no recorded.
There is nothing in the logs that can indicate a problem...
Koenzie
Post
by Koenzie » Mon Dec 12, 2005 10:29 am
Maybee it has something to do with permissions ? i see the frame where the video has te be placed, the same size as the live video
Koenzie
Post
by Koenzie » Tue Dec 13, 2005 9:31 am
Other idea's someone ?
jameswilson
Posts: 5111 Joined: Wed Jun 08, 2005 8:07 pm
Post
by jameswilson » Tue Dec 13, 2005 9:53 am
dafyt one, i suppose you have it in a record mode? not monitor
Koenzie
Post
by Koenzie » Tue Dec 13, 2005 10:13 am
jameswilson wrote: dafyt one, i suppose you have it in a record mode? not monitor
Yes, it records, but i can only see the recorded stills and not the video
(tryed the mpeg option today, but it doesnt work with that also)
