As i see that panasonic cams are supported now is this one too?
james
Panasonic KX-HCM280
- Contact:
- Contact:
also it seems its easier to get hold of the BB-HCM381 will this onw work too??
JAmes
http://panasonic.co.jp/pcc/products/en/ ... cm381.html
JAmes
I'd be leary of the last one you posted the link to.
I hope I'm wrong.
Regards,
Cordel
That's for the audio though. It does do mjpeg for video but it may depend on how they serve it.Audio Play Method Play with Active X
Input Encoding Method Encoding with Active X
With no mention of any other browser so it may require active xWeb browser Internet Explorer 6.0 or later
Regards,
Cordel
- Contact:
Im thinking of borrowing one to see. I have asked the protocols. As the little c10 is upported by zm(i think) i was hoping they were similar. Someone from panasonic is geting back to me. From what i have been told they work the same so heres hoping.
One question though, on my live cd'ed zm i have pelco and visca as protocols no axis panasonic etc.
James
James
I'm not sure but the Pelco and visca are wired cams, could it be that your looking for the option in the config for a wired cam (not sure if Phil made it that smart but, I would not suprise me if he did
Other wise you may need to either update ZM or you could just down load the source and just upload the profiles for those cameras protocals.
Regards,
Cordel
Regards,
Cordel
- Contact:
- zoneminder
- Site Admin
- Contact:
Users browsing this forum: No registered users and 9 guests
