I am new to Mandrake and linux in general. But I need to get to the ZM Box remotely. I would like to know how do I install and setup ssh and vnc to the xwindow of the system.
It's up and running fine. Also would you recommend more memory for 9 CAMs then 512mg of ram on a celeron 2.8?
Thank you for the replys.
ZM LiveCD installed on HD. I need to add ssh to it.
320X240 max 7 fps. buffers. Hum I have not changed this from the default. What should I put there?jameswilson wrote:what capture rate and resolution you on on your 8 cams? I have run upto 16 on 512 with no probs and only about 15 meg paged. I think it matters what your buffers are set to really and your res and cap rate
ssh is installed and running by default.
vnc is installed. To config it see this thread:
http://www.zoneminder.com/forums/viewto ... hlight=vnc
