Shell script for burning events to CD-ROM
Baylink
Post by Baylink »
I'm not entirely complete with this yet, but I'm posting it anyway because the hard 90% is done, and all that's left is the other 90%, with which I could use some help. :-)
#!/bin/bash
# burnevents -- burn a CD with ZoneMinder event files on it
# Written Fri Jun 24 10:30:05 EDT 2005 by jra@microsys.us
# extract the events for a day, by default "yesterday", find the event directories
#  convert the JPEGs to a pair of MPEG's (which might be a bitch, since only certain
#  frames get analyze counterparts), and rename to Name-Timestamp(-analyze).mpg
# zeroth, set magic variables
ZMHOME=/appl/zm1211
MPEGDIR=/appl/zm1211/mpeg
CDRDEV=/dev/hdc
FFMPEG=
ZMPASS=mumble
# first, calculate yesterday
# YESTERDAY=`date -d "-1 day" +%Y-%m-%d`        # "normal": do yesterday
YESTERDAY=`date +%Y-%m-%d`                      # test: do today
STARTTIME="$YESTERDAY 00:00:00"
ENDTIME="$YESTERDAY 23:59:59"
# set -vx
cd $ZMHOME/events
mysql -u zm --password=$ZMPASS -D zm -B \
        -e "SELECT MonitorId,Id,Name FROM Events \
        WHERE StartTime > \"$STARTTIME\" and StartTime <= \"$ENDTIME\" \
        ORDER BY MonitorID,Id" | sed 1d |
while read MONITOR EVENT NAME
do
        pushd $MONITOR || continue      # skip the line without getting confused
                                        # if monitor directory not there
        pushd $EVENT || (popd;continue) # same thing for the event directory
        # Now, we're in the right place.  Grab the timestamp off the first jpeg,
        # then build the mpeg and name it appropriately
        TIMESTAMP=`date -r \`ls | head -1\` -Iminutes`
        echo ffmpeg -i %d-capture.jpg $MPEGDIR/$NAME-$TIMESTAMP.mpg
        ffmpeg $FFMPEG -i %d-capture.jpg $MPEGDIR/$NAME-$TIMESTAMP.mpg
        popd    # event dir
        popd    # monitor dir
done
# now burn them
cd $MPEGDIR
# mkisofs -rJ * | cdrecord -immed $CDRDEV
# and remove them.
mv * archive/
Clearly, I'm not entirely done with it -- I haven't gotten to tuning the burning commands yet because I haven't quite figured out what to tell ffmpeg to get Windows-playable video files that the users will be able to navigate around in. This machine is on-net at the moment, but they don't necessarily need it to be, and the wireless (only practical option) is being cranky.
So, first, any suggestions on $FFMPEG?
Once I get that done, I'll look into how hard doing a companion clip with the analysis frames will be; annoying, I suspect (involving making symlinks for all analyze frames that don't exist)...
Baylink
Post by Baylink »
I seem to reply to myself a lot around here...
After extensive debugging, I seem to have a *very* strange problem with my script, which now looks like this:
#!/bin/bash
ZMHOME=/appl/zm1211
MPEGDIR=/appl/recordings/mpeg
CDRDEV=/dev/hdc
# set -vx
cd $ZMHOME/events
mysql -u zm --password=zomeminter -D zm \
while read xMONITOR xEVENT xNAME
do
        # Sign on
        echo "Processing $xMONITOR/$xEVENT/$xNAME" >&2
        # check to make sure the event directory exists, or skip the event
        [ -d "$xMONITOR/$xEVENT" ] || {
                echo "=== Skipping $xMONITOR/$xEVENT -- no directory ===" >&2
                continue
        cd $xMONITOR/$xEVENT
        TIMESTAMP="`date -r \`ls | head -1\` -Iminutes`"
        CLIPNAME="${MPEGDIR}/${xNAME}-${TIMESTAMP}.mpg"
        ffencode $CLIPNAME
        cd ../..
        echo >&2
        sleep 2
done
# now burn them
cd $MPEGDIR
#mkisofs -rJ * | cdrecord -immed $CDRDEV
# and remove them.
#mv * archive/
and ffencode is just
ffmpeg -vcodec msmpeg4 -acodec mp3 -r 3 -i %05d-capture.jpg $1
and in case anyone's wondering *why* that is in a subscript, it's because the main script's loop breaks if I call ffmpeg from it. Even if I call it from a subscript. If I comment out the call, it counts through the event info returned to the while loop from mysql just perfectly. If I call ffmpeg, then that stream of data gets screwed up, dropping some lines completely, and others partially.
I, and my shell programmer cow-orker, are both flummoxed. This is the Last Bug; anyone got any ideas?
Incidentally, even when the data gets hosed, those second and third "echo Processing" statements both return the same thing.
b.addis
useful
Post by b.addis »
Hey
This looks mighty useful, have you managed to find a fix at all?
I don't need the cd writing part, but the rest would be most useful.
Cheers!
nickcol
Post by nickcol »
Is the above script working yet ?.
I have tried the
line by itself to encode 1 jpg to mpg and just get
001-capture.jpg unknown format.
Nick
slide
mmh... Something goes wrong
Post by slide »
Why i get this error ?
/usr/lib/zm/html/events/4 /usr/lib/zm/html/events
/usr/lib/zm/html/events/4/7567 /usr/lib/zm/html/events/4 /usr/lib/zm/html/events
ffmpeg -y -r 2.19 -i %04d-capture.jpg -s 480x360 -r 25 /home/executive/VideoRec//Event-7567-2007-04-04T06:00+0200.mpg
ffmpeg version CVS, build 3277056, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --prefix=/usr --libdir=/usr/lib --mandir=/usr/share/man --enable-mp3lame --enable-libogg --enable-vorbis --enable-theora --enable-faad --enable-faac --enable-xvid --enable-a52 --enable-a52bin --enable-pp --enable-shared-pp --enable-shared --enable-pthreads --enable-gpl --disable-opts --disable-strip
built on Feb 17 2006 14:32:43, gcc: 3.4.4 20050721 (Red Hat 3.4.4-2)
Input #0, image2, from '%04d-capture.jpg':
Duration: 00:09:28.9, start: 0.000000, bitrate: N/A
Stream #0.0, 2.19 fps: Video: mjpeg, gray, 320x240
Output #0, mpeg, to '/home/executive/VideoRec//Event-7567-2007-04-04T06:00+0200.mpg':
Stream #0.0, nan fps: Video: mpeg1video, yuv420p, 480x360, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
frame=14212 q=0.0 Lsize= 14358kB time=568.4 bitrate= 206.9kbits/s
video:291kB audio:0kB global headers:0kB muxing overhead 4840.104900%
/home/executive/ZM_video2.sh: line 37: pushd: Event-7689: No such file or directory
/usr/lib/zm/html/events/5 /usr/lib/zm/html/events
there's something wrong but i cant understand what in your script made this
for ffmpeg command i prefer this:
$FFMPEG -y -r 2.19 -i %04d-capture.jpg -s 480x360 -r 25 $MPEGDIR/$NAME-$TIMESTAMP.mpg
gab74
Post by gab74 »
Anyone has the above scritp funcional ??
i try the above scripts but it is bugged......
________
VERMONT DISPENSARIES
Baylink
Post by Baylink »
I never came back to it... but I may shortly, I'm back on this horse again.
