Colour not working
gungner
Colour not working
Post by gungner » Thu Mar 03, 2005 8:04 pm
Now when I have bought a colour camera I just can't get it working. I'm on MDK 10.1 OE and all cameras are working on grey-palett, but not on any other settings, zmc just craches with err=255.
I've a BT878 board with 4 input, running zmu gives:
Video Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 640
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 384
Height: 287
Picture Attributes
Palette: 1 - Linear greyscale
Colour Depth: 8
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 3 - AUTO
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 3 - AUTO
The only way it works it with GREY and device format = 3. It should I think work on device format=0 since it's a PAL camera, any ideas?
cheers, tord
cordel
Post by cordel » Thu Mar 03, 2005 8:30 pm
This is a limitation of your capture card more than likely.
Single chip BT878 cards must have all ports configured for the same size and color pallet.
Cheers,
Cordel
gungner
Post by gungner » Thu Mar 03, 2005 8:38 pm
yes, you are right, but if I only got one camera on the board, shouldn't that be enougth, or do I've to setup all four even although I only have one camera?
thanks
cordel
Post by cordel » Thu Mar 03, 2005 8:57 pm
All configured ports must match. So if you only set up the one port on that card then you should be okay. Have you tried verious color pallets to see if maybe the one your using is not supported by the card?
gungner
Post by gungner » Fri Mar 04, 2005 6:16 am
yes I've tried them all, every one with different device format as well, it just don't give a colour :cry: Most of the pallets crashes zmc. When I try to send USR1 to the zmc deamon some more pallets works without crash, but still no colour.
thanks for your help!
maciekc
Post by maciekc » Fri Mar 04, 2005 3:50 pm
Maybe you have bad card number set in bttv configuration? For 4 bnc input card bt878 try to use 77.
gungner
Post by gungner » Fri Mar 04, 2005 4:39 pm
thanks, how do I change that?
cordel
Post by cordel » Sat Mar 05, 2005 5:09 am
If that is the case the file is /etc/modprobe.conf on most distros. You can find a list in the kernel documents that goes over the card types. You can do a search for that file on this forum and get an idea of what you need to do. It all depends on what card you have.
Cheers,
Cordel
gungner
Post by gungner » Sat Mar 05, 2005 7:03 am
thanks for that Cordel, I've manged now to set the board type to 77 (it works for my first board, but the second board still loads on card=0. I don't know how to pass the parameters to my second board)
Still no colour :cry: zmc just crash with exit=255 when I try setting anything outside grey.
For a PAL camera on composite video, should it not just be RGB24, device format=0 (PAL) and capture with in my case 384x287?
Cheers,
tord
cordel
Post by cordel » Sat Mar 05, 2005 7:07 am
just put a comma after 77 and to ID for the second card. So if both cards are the same do
77,77
cheers,
Cordel
gungner
Post by gungner » Sat Mar 05, 2005 7:15 am
the dogs mate! it's getting closer, only thing missing now is colour :cry:
my modprobe.conf now looks like:
options bttv radio=0 tuner=0 pll=0 gbuffers=8 card=77,77
On the good side, I now get colours from another application, 'camstreams'. That must mean that the capture board is working, problem back to ZM. Any ideas?
cheers,
tord
cordel
Post by cordel » Sat Mar 05, 2005 8:10 am
the zero option for tuner could probably be set to 4,4
If I remember correctly 0 is autodetect and 4 means it has no tuner
All your options should probably be set like so so both cards get the config like so:
options bttv radio=0,0 tuner=4,4 pll=0,0 card=77,77
gungner
Post by gungner » Sat Mar 05, 2005 8:36 am
thans for that, both cards now deliver colour, but not through ZM(?) still only grey, no other device format works.
Can Width x Height have any connection to that zmc craches?
Cheers, tord
cordel
Post by cordel » Sat Mar 05, 2005 8:56 am
Yes it can. If the settings you have in ZM don't match what the card can deliver ZM will crash. But I think ZM will give you an error that will suggest that maybe the issue but I'm not sure.
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
gungner
Post by gungner » Sat Mar 05, 2005 2:01 pm
so if I use 384x287 that works with grey should it not also work with RGB24?
What are you using?
cheers, tord
Users browsing this forum: No registered users and 14 guests
