http://www.zoneminder.com/forums/viewtopic.php?t=3413
I have a problem with bttv.
Ross suggested to boot with noapic and pci=noacpi I think to solve irq problems. I hope this work but i'd like to update the kernel to 2.6.6 because as you can read from http://www.kernel.org/pub/linux/kernel/ ... eLog-2.6.6
new kernel should restore images after a chip reset and make bttv give zmc good images even after a Sync Failure..<akpm@osdl.org>
[PATCH] v4l: bttv driver update
This patch updates the bttv driver. Changes:
(1) several card-specific tweaks.
(2) make software vs. hardware i2c configurable per TV card.
(3) reinitialize image parameters after chip reset.
(4) make bttv quite by default on frame drops.
(5) new insmod option: "debug_latency=1" to enable frame drop
debug messages.
bttv is quite sensitive to irq latencies, especially when capturing both
video and vbi. There are several reports about problems due to this, I don't
see that on my machines through. (5) dumps a stracktrace if the driver
thinks the frame drop is is caused by high latencies as experiment, lets see
whenever that helps ...
Can you help me updating the kernel? I tryed before but without success on LiveCD1.17.0 installation.
Any link to a procedure to follow for safely update a 2.6.3 to 2.6.6?
thanks,
