merging events
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
laad
merging events
Post by laad »
Hi
ZoneMinder is working just fine, yet I've a small proposal:
what is to add an option to merge events into one if one goes after another in, for example, less than 5 seconds time?
zoneminder
Site Admin
Re: merging events
Post by zoneminder »
Hi Alexander,
The issue of merging events has been mentioned before and I'll look at adding that in the future. In the meantime you can expand your post-event buffer to increase the amount of frames that need to be unalarmed before an event is finished. So if you camera is capturing at 5fps, then a post-event buffer of 25 will effectively be the same as 5 seconds.
Cheers,
Phil,
