Connecting to external database (solution)
Support for the docker image maintained by dlandon
PencilGeek
Post by PencilGeek »
I have mysql:latest running in a docker container and presenting itself as a docker network node to other multiple docker containers. When trying to get ZoneMinder to work with an external database, I saw many people trying to figure out how to solve this problem. Many hackable proposals, but few people said "aha, I got this to work!" So, here's my docker-compose.yml file with a working solution. This includes my docker sql server configuration.
For security reasons, the ZM database user zoneminder-docker_rw is unique to this docker image and only has access to this one database. This was set beforehand in my networked sql server.
Caveat: I needed to create the ZoneMinder database in advance. Like others, this was a stumbling block. To solve this problem, I got ZM running without my external sql server. Once running, I ran mysqldump to export the basic ZM database structure. I imported this dump into my networked mysql server, and voila...the following configuration will work. I also needed to set the TZ in the mysql docker container otherwise ZM would complain about a misconfiguration during initialization.
# Creates mysql container and phpMyAdmin service to manage it
# Video at https://www.youtube.com/watch?v=NdwB5TPXCnQ explains the file
networks:
  # This will create a user-defined network with name of mysql-net
  # Specify name so that it does not append stack name and become db_mysql-net
  mysql-net:
    driver: bridge
volumes:
  # Creates persistent storage volume for database
  # Specify name so it does not append stack name in front
  mysqldata:
    driver: local
    driver_opts:
        type: 'none'
        o: 'bind'
        device: '/raid/www-docker/mysql'
services:
  mysql:
    image: mysql:latest
    container_name: mysql
    hostname: mysql
    restart: always
    environment:
      MYSQL_ROOT_PASSWORD: ********
      TZ: America/Los_Angeles
    ports:
      - "6033:3306"
    volumes:
      # Will use db volume and inside to path /var/lib/mysql
      - mysqldata:/var/lib/mysql
      - /raid/rcollins/tmp:/raid/rcollins/tmp
    networks:
      - mysql-net
# Install phpmyadmin to help administer mysql
  phpmyadmin:
    # Depends on only works within same stack, but not between remote containers (even on user-defined network)
    depends_on:
      - mysql
    image: phpmyadmin/phpmyadmin
    restart: always
    networks:
      - mysql-net
    container_name: phpmyadmin
    hostname: phpmyadmin
    ports:
      # Exposes external port 7000 mapped to internal of 80
      # Database required no external port of its own
      - 7000:80
    environment:
      PMA_HOST: mysql
      PMA_PORT: 3306
      # Variable to increase upload limit for importing sql db files
      UPLOAD_LIMIT: 200000K
   zoneminder:
    depends_on:
      - mysql
    container_name: zoneminder
    image: zoneminderhq/zoneminder:latest-ubuntu18.04
    restart: always
    networks:
      - mysql-net
    ports:
      # Exposes external port 9010 mapped to internal of 80
      - 9010:80
    privileged: true
    shm_size: 512M
    environment:
      ZM_DB_HOST: mysql
      ZM_DB_USER: zoneminder-docker_rw
      ZM_DB_NAME: ZoneMinder
      ZM_DB_PASS: ********
      ZM_TIMEZONE: America/Los_Angeles
    volumes:
      - /raid/www-docker/ZoneMinder/events:/var/cache/zoneminder/events
      - /raid/www-docker/ZoneMinder/images:/var/cache/zoneminder/images
      - /raid/www-docker/ZoneMinder/logs:/var/log/zm
