Issues with modect
hornetster
Issues with modect
Post by hornetster »
Have just setup an additional camera (Nextech QC3864 - pretty useless...), and trying to get motion detect to work.
Works OK for the initiall "All" area, but if I try and setup another area, doesn't seem to matter what I do, it will not detect.
Have tried to copy (mostly) the settings from the All area, but still no good. Have set to Fast, high/best, high, etc, but no good.
Where am I going wrong?
Thanks.
OpensuseTumbleweed/PLASMA
Ubuntu24.04
ZoneminderV1.36.33
Andyrh
Re: Issues with modect
Post by Andyrh »
Likely it is the detection threshold. I changed to pixels instead of percent to gain tighter control.
My trick is to find a person sized object in the frame and draw a tight zone around it. The zone properties will tell me the pixel count. I delete the test zone and set the detection size to the same pixel count as the test box. Once that is done, I adjust up or down as needed, but those adjustments are usually small.
Does that help?
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
hornetster
Thanks Andy.
Think it is more the dodgy chinese camera, but will continue trying...
Ubuntu24.04
ZoneminderV1.36.33
Here is a good how to for motion detection: https://wiki.zoneminder.com/Understandi ... or_Dummies
One thing I've found is that the settings can be too sensitive and you will get a lot of worthless detection's. Fog, snow and rain can fill up the storage. But with Zoneminder even iffy cams can be made to work well!
