No concole or web inferface after upgrade
swolsen
Post by swolsen »
Just upgraded to 1.36.35 from 1.36.34 and no longer have a web interface. Just a white screen. Not sure what happened.
Re: No concole or web inferface after upgrade
Please check apache logs. /var/log/apache2/error.log. The answer will be there. I can't think of any change that would cause this, but again... the answer will be there.
swolsen
Post by swolsen »
I just did a purge and removed zoneminder completely. Reinstalled but still same problem.
apache error log has
[Tue Oct 22 19:53:10.711371 2024] [php:error] [pid 1835] [client 192.168.54.88:43956] PHP Fatal error: Uncaught Error: Call to undefined method IntlDateFormatter::setPatter() in /usr/share/zoneminder/www/index.php:58\nStack trace:\n#0 {main}\n thrown in /usr/share/zoneminder/www/index.php on line 58
looking at page source for web interface just has a "1"
gavinwa
Post by gavinwa »
This appears to be a typo with this version. I edited /usr/share/zoneminder/www/index.php and on line 58 I changed:
  $dateFormatter->setPatter(ZM_DATE_FORMAT_PATTERN);
to
  $dateFormatter->setPattern(ZM_DATE_FORMAT_PATTERN);
swolsen
Post by swolsen »
Yes, that worked. Thank you.
Oh no! Now I have to do another release! Crap.
mr.goose
Post by mr.goose »
gavinwa wrote: Wed Oct 23, 2024 5:20 am This appears to be a typo with this version. I edited /usr/share/zoneminder/www/index.php and on line 58 I changed:
to
Thanks for posting this. Fixed it for me too! :)
rcnn
Post by rcnn »
Fixed with (container name here is zm):
docker cp zm:/var/www/html/index.php ./patch
vim ./patch/index.php (line 58, replace as written above)
add to docker-compose.yml
volumes:
  - ./patch/index.php:/var/www/html/index.php:ro
