After upgrade to 1.36.34 zmeventnotification fails to log in
Posted: Mon Oct 07, 2024 8:44 pm
System: Debian 10. After upgrade to 1.36.34 test run of notification service shows the following:
corresponding contents of /var/log/zm/error.log:
Would be grateful for any clues or suggestions
sudo -u www-data zmeventnotification/bin/zm_detect.py -l --config /etc/zm/objectconfig.ini --eventid 1474046 --monitorid 2 --debug
10/07/24 23:31:02 zmesdetect_m2[9690] INF ZMLog.py:292 [Setting up signal handler for logs]
10/07/24 23:31:02 zmesdetect_m2[9690] INF ZMLog.py:301 [Switching global logger to ZMLog]
10/07/24 23:31:03 zmesdetect_m2[9690] INF zm_detect.py:282 [---------| app:6.1.28, pyzm:0.3.63, ES:6.1.28
, OpenCV:4.10.0-dev|------------]
10/07/24 23:31:03 zmesdetect_m2[9690] INF utils.py:404 [Reading config from: /etc/zm/objectconfig.ini]
10/07/24 23:31:03 zmesdetect_m2[9690] INF utils.py:409 [Reading secrets from: /etc/zm/secrets.ini]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ZM_PORTAL]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ZM_USER]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ZM_PASSWORD]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ZM_API_PORTAL]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ML_USER]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ML_PASSWORD]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !PLATEREC_ALPR_KEY]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG1 utils.py:444 [allowing self-signed certs to work...]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:454 [Now checking for monitor overrides]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:174 [import_zm_zones: match_reason=False and reason=None]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:177 [Getting ZM zones using http://localhost/zm/api/zones/forMonitor/2.json?username=xxx&password=yyy&user=xxx&pass=yyy]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:227 [importing zoneminder polygon: xxxx [659,356 1134,158 1124,540 880,719]]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:227 [importing zoneminder polygon: walk [800,762 1135,523 1918,825 1297,1079]]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:227 [importing zoneminder polygon: outside [0,0 904,1 1252,188 0,935]]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG3 utils.py:521 [Finally, doing parameter substitution]
10/07/24 23:31:03 zmesdetect_m2[9690] INF zm_detect.py:307 [Importing local classes for Object/Face]
10/07/24 23:31:03 zmesdetect_m2[9690] INF zm_detect.py:332 [Connecting with ZM APIs]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 api.py:69 [API SSL certificate check has been disbled]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG1 api.py:173 [using username/password for login]
10/07/24 23:31:03 zmesdetect_m2[9690] ERR api.py:223 [Got API login error: 500 Server Error: Internal Server Error for url: http://localhost/zm/api/host/login.json]
10/07/24 23:31:03 zmesdetect_m2[9690] FAT zm_detect.py:564 [Unrecoverable error:500 Server Error: Internal Server Error for url: http://localhost/zm/api/host/login.json Traceback:Traceback (most recent call last):
File "/mnt/video/zmeventnotification/bin/zm_detect.py", line 559, in <module>
main_handler()
File "/mnt/video/zmeventnotification/bin/zm_detect.py", line 333, in main_handler
zmapi = zmapi.ZMApi(options=api_options)
File "/usr/local/lib/python3.7/dist-packages/pyzm-0.3.63-py3.7.egg/pyzm/api.py", line 76, in __init__
self._login()
File "/usr/local/lib/python3.7/dist-packages/pyzm-0.3.63-py3.7.egg/pyzm/api.py", line 225, in _login
raise err
File "/usr/local/lib/python3.7/dist-packages/pyzm-0.3.63-py3.7.egg/pyzm/api.py", line 195, in _login
r.raise_for_status()
File "/usr/lib/python3/dist-packages/requests/models.py", line 940, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http://localhost/zm/api/host/login.json
2024-10-07 23:31:03 Error: [MissingViewException] View file "Host/json/login.ctp" is missing.
Exception Attributes: array (
'file' => 'Host/json/login.ctp',
Request URL: /zm/api/host/login.json?p=%2Fhost%2Flogin.json
Stack Trace:
#0 /usr/share/zoneminder/www/api/lib/Cake/View/JsonView.php(107): View->_getViewFileName('Host/json/login')
#1 /usr/share/zoneminder/www/api/lib/Cake/Controller/Controller.php(968): JsonView->render(NULL, NULL)
#2 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(200): Controller->render()
#3 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(167): Dispatcher->_invoke(Object(HostController), Object(CakeRequest))
#4 /usr/share/zoneminder/www/api/app/webroot/index.php(117): Dispatcher->dispatch(Object(CakeRequest), Object(CakeResponse))
#5 {main}
