After upgrade to 1.36.34 zmeventnotification fails to log in
zmevtuser
Post by zmevtuser »
System: Debian 10. After upgrade to 1.36.34 test run of notification service shows the following:
sudo -u www-data zmeventnotification/bin/zm_detect.py -l --config /etc/zm/objectconfig.ini  --eventid 1474046 --monitorid 2 --debug
10/07/24 23:31:02 zmesdetect_m2[9690] INF ZMLog.py:292 [Setting up signal handler for logs]
10/07/24 23:31:02 zmesdetect_m2[9690] INF ZMLog.py:301 [Switching global logger to ZMLog]
10/07/24 23:31:03 zmesdetect_m2[9690] INF zm_detect.py:282 [---------| app:6.1.28, pyzm:0.3.63, ES:6.1.28
 , OpenCV:4.10.0-dev|------------]
10/07/24 23:31:03 zmesdetect_m2[9690] INF utils.py:404 [Reading config from: /etc/zm/objectconfig.ini]
10/07/24 23:31:03 zmesdetect_m2[9690] INF utils.py:409 [Reading secrets from: /etc/zm/secrets.ini]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ZM_PORTAL]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ZM_USER]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ZM_PASSWORD]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ZM_API_PORTAL]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ML_USER]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !ML_PASSWORD]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:381 [Secret token found in config: !PLATEREC_ALPR_KEY]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG1 utils.py:444 [allowing self-signed certs to work...]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:454 [Now checking for monitor overrides]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:174 [import_zm_zones: match_reason=False and reason=None]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:177 [Getting ZM zones using http://localhost/zm/api/zones/forMonitor/2.json?username=xxx&password=yyy&user=xxx&pass=yyy]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:227 [importing zoneminder polygon: xxxx [659,356 1134,158 1124,540 880,719]]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:227 [importing zoneminder polygon: walk [800,762 1135,523 1918,825 1297,1079]]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 utils.py:227 [importing zoneminder polygon: outside [0,0 904,1 1252,188 0,935]]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG3 utils.py:521 [Finally, doing parameter substitution]
10/07/24 23:31:03 zmesdetect_m2[9690] INF zm_detect.py:307 [Importing local classes for Object/Face]
10/07/24 23:31:03 zmesdetect_m2[9690] INF zm_detect.py:332 [Connecting with ZM APIs]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG2 api.py:69 [API SSL certificate check has been disbled]
10/07/24 23:31:03 zmesdetect_m2[9690] DBG1 api.py:173 [using username/password for login]
10/07/24 23:31:03 zmesdetect_m2[9690] ERR api.py:223 [Got API login error: 500 Server Error: Internal Server Error for url: http://localhost/zm/api/host/login.json]
10/07/24 23:31:03 zmesdetect_m2[9690] FAT zm_detect.py:564 [Unrecoverable error:500 Server Error: Internal Server Error for url: http://localhost/zm/api/host/login.json Traceback:Traceback (most recent call last):
  File "/mnt/video/zmeventnotification/bin/zm_detect.py", line 559, in <module>
    main_handler()
  File "/mnt/video/zmeventnotification/bin/zm_detect.py", line 333, in main_handler
    zmapi = zmapi.ZMApi(options=api_options)
  File "/usr/local/lib/python3.7/dist-packages/pyzm-0.3.63-py3.7.egg/pyzm/api.py", line 76, in __init__
    self._login()
  File "/usr/local/lib/python3.7/dist-packages/pyzm-0.3.63-py3.7.egg/pyzm/api.py", line 225, in _login
    raise err
  File "/usr/local/lib/python3.7/dist-packages/pyzm-0.3.63-py3.7.egg/pyzm/api.py", line 195, in _login
    r.raise_for_status()
  File "/usr/lib/python3/dist-packages/requests/models.py", line 940, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http://localhost/zm/api/host/login.json
corresponding contents of /var/log/zm/error.log:
2024-10-07 23:31:03 Error: [MissingViewException] View file "Host/json/login.ctp" is missing.
Exception Attributes: array (
  'file' => 'Host/json/login.ctp',
Request URL: /zm/api/host/login.json?p=%2Fhost%2Flogin.json
Stack Trace:
#0 /usr/share/zoneminder/www/api/lib/Cake/View/JsonView.php(107): View->_getViewFileName('Host/json/login')
#1 /usr/share/zoneminder/www/api/lib/Cake/Controller/Controller.php(968): JsonView->render(NULL, NULL)
#2 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(200): Controller->render()
#3 /usr/share/zoneminder/www/api/lib/Cake/Routing/Dispatcher.php(167): Dispatcher->_invoke(Object(HostController), Object(CakeRequest))
#4 /usr/share/zoneminder/www/api/app/webroot/index.php(117): Dispatcher->dispatch(Object(CakeRequest), Object(CakeResponse))
#5 {main}
Would be grateful for any clues or suggestions
zmevtuser
Re: After upgrade to 1.36.34 zmeventnotification fails to log in
Post by zmevtuser »
To moderators: if this post relates to zmeventnotification more than to zoneminder, please consider moving this topic to the relevant section
burger
Post by burger »
What happens when you test the API outside of ZMES? See: https://wiki.zoneminder.com/API for instructions.
This error looks like it's with CakePHP, and the controller is not that complicated if you dig into it. I wrote something about it here: https://wiki.zoneminder.com/API#Finding ... in_the_API Is the https://github.com/ZoneMinder/zoneminde ... roller.php file there? Did the upgrade get corrupted somehow? I'd look at the filesystem, then enable debugging in CakePHP.
If you have a working environment, you can compare the differences between the debug logs of CakePHP from one to the other. That should reveal something.
fastest way to test streams:
zmevtuser
Post by zmevtuser »
Thank you for the reply, http://localhost/zm/api/host/getVersion.json returns with successful response, however http://localhost/zm/api/host/login.json produces an error:
{"success":false,"data":{"name":"An Internal Error Has Occurred.","message":"An Internal Error Has Occurred.","url":"\/zm\/api\/host\/login.json?p=%2Fhost%2Flogin.json","exception":{"class":"MissingViewException","code":500,"message":"View file \"Host\/json\/login.ctp\" is missing."}}}
Checked package integrity (dpkg -V zoneminder), found no issues except changed config files. Error message states that login.ctp is missing and there is indeed no such file anywhere, but I could not find it in the DEB package either. Previous versions also do not have it.
This generally happens when you have auth turned off. Is fixed in 1.36.35 proposed.
zmevtuser
Post by zmevtuser »
Thank you, I turned on authentication and script works.
