unable to add a rtsp camera
funix
Post by funix »
I use 1.36.33 with linux/mageia 9 and I am not able to add a rtsp IP camera, I try all combination between source and camera without success.
I can connect and it works without problem with ffmpeg in a shell with the command
ffplay rtsp://admin:password@192.168.2.110
Somebody can guide me to setup this camera ?
_______________________
Blog https://olivier.hoarau.org
Funix https://www.funix.org
lbm
Re: unable to add a rtsp camera
Post by lbm »
  • Which camera is it
    Can you share your settings for the camera ?
    Do you hany any specific errors, other than "not working" ?
Mine (hikvision) looks like this.
rtsp://USER:PASS@IP//Streaming/Channels/1
funix
Post by funix »
It's an annke I51DL camera
below a screenshot of the dashboard
the source setup, I have tried all the methods (RTP/Unicast, multicast, RTSP, RTSP/HTTP), the path with ou without rtsp:// or user:password without sucess
the camera setup
and error log file
août 13 14:47:28 ultra.kervao.fr zmc_m1[657020]: ERR [zmc_m1] [Can't getaddrinfo(camera port 80): Name or service not known]
août 13 14:47:29 ultra.kervao.fr zmc_m1[657020]: ERR [zmc_m1] [connect(): getaddrinfo: Name or service not known]
août 13 14:47:29 ultra.kervao.fr zmc_m1[657020]: FAT [zmc_m1] [Unable to connect RTSP socket]
août 13 14:47:29 ultra.kervao.fr zmdc[656617]: ERR ['zmc -m 1' exited abnormally, exit status 255]
funix
Post by funix »
oups ! there is my password in the image, I change it :)
lbm
Post by lbm »
If you in general on the camera, change it to ffmpeg, you will get some different options in source type.
Then on Method, select TCP, and in the source path, use the full rtsp:// url like so "rtsp://USER:PASS@IP//Streaming/Channels/1"
Im not sure, how the full path will look like on your camera though.
funix
Post by funix »
ffplay works in a console only with rtsp://admin:password@192.168.2.110, so I tried it
now in the dashboard, the source is green, the camera orange, but still no image
the error log is different
août 13 15:09:47 ultra.kervao.fr zmc_m1[657771]: ERR [zmc_m1] [Unable to open input "rtsp://192.168.2.110" due to: No such file or directory]
août 13 15:09:47 ultra.kervao.fr zmc_m1[657771]: ERR [zmc_m1] [Failed to prime capture of initial monitor]
funix
Post by funix »
it works ! I had some trouble with my apache conf
