nothing gets captured
aag
Post by aag »
Hello, newbie here. I managed to set up ZM with a Hikvision IP camera on an Ubuntu virtual machine (hosted on a Win server). Streaming works, no major errors are thrown in the logs, and yet I don't get anything captured. I am certain that I am doing some trivial error, but I don't know what. Might you be able to help?
Screenshot 2024-07-25 211710.png (70.6 KiB) Viewed 3276 times
Screenshot 2024-07-25 212150.png (25.39 KiB) Viewed 3276 times
Screenshot 2024-07-25 212044.png (41.43 KiB) Viewed 3276 times
aag
Re: nothing gets captured
Post by aag »
Screenshot 2024-07-25 212216.png (237.9 KiB) Viewed 3275 times
aag
Post by aag »
Update. I seem to have solved the issue (perhaps) by reducing the alarm frame blending to 3.125% and the Min/Max Alarmed area to 5%. Let's hope for the best...
burger
Post by burger »
The min/max area you had at 10% was probably too high.
See: https://wiki.zoneminder.com/Dummies_Guide#Example_Zone (note that this example is for a low res stream).
Also, you are modecting on a high resolution image. You may want to consider the following:
https://wiki.zoneminder.com/Dummies_Gui ... Zoneminder
fastest way to test streams:
aag
Post by aag »
Thank you! But now I am getting too many false-positives. I am playing around with adding many different zones in order to find out where the positives come from. Maybe it's good to set a max limit to the percentage of alarmed pixels, so that sudden changes to the whole pic (e.g. the camera switching on IR lights at night) won't trigger.
burger
Post by burger »
Right, you are learning first hand the difficulty of tuning zones, and I don't have an easy answer for you. Some false alarms can be avoided by raising the min alarmed area (for me pixels is easier to tune than percent), but it's a rabbit hole. I find ZMES and email alerts works well at the expense of more CPU (so I only use it on certain monitors).
There's been a bit written about tuning zones on the forums, so search and that may help.
