Event recording
stinga
Event recording
Post by stinga »
G'day all
v1.36.33
I have 5 reolink cameras of various descriptions
I have one camera That is not quite correct.
lodef:
I use the lower resolution, 640x360, in Mocord (lodef)
hidef:
High resolution 3840x2160 in Nodect and linked to lodef stream (hidef)
I encode the storage using h264 and libx264 as the camera is h265
When I play an event...
lodef:
I get audio and I can scrub back and forth and it works well
Bottom of video I see: progress bar, play/pause, time/length
hidef:
No audio and I can't scrub back and forth
Bottom of video I see: progress bar that does not move, play/pause and it states 'live'
From the camera
root@octopus:~# ffmpeg -i rtsp://<user>:<password>@cctv-03.wolf-rock.com:554//h265Preview_01_main
ffmpeg version 4.1.11-0+deb10u1 Copyright (c) 2000-2023 the FFmpeg developers
  built with gcc 8 (Debian 8.3.0-6)
  configuration: --prefix=/usr --extra-version=0+deb10u1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
  libavutil      56. 22.100 / 56. 22.100
  libavcodec     58. 35.100 / 58. 35.100
  libavformat    58. 20.100 / 58. 20.100
  libavdevice    58.  5.100 / 58.  5.100
  libavfilter     7. 40.101 /  7. 40.101
  libavresample   4.  0.  0 /  4.  0.  0
  libswscale      5.  3.100 /  5.  3.100
  libswresample   3.  3.100 /  3.  3.100
  libpostproc    55.  3.100 / 55.  3.100
Input #0, rtsp, from 'rtsp://zoneminder:gah2ohro4Ute6eeph9@cctv-03.wolf-rock.com:554//h265Preview_01_main':
  Metadata:
    title           : Session streamed by "preview"
    comment         : h265Preview_01_main
  Duration: N/A, start: 0.000313, bitrate: N/A
    Stream #0:0: Video: hevc (Main), yuv420p(tv), 3840x2160, 90k tbr, 90k tbn, 90k tbc
    Stream #0:1: Audio: aac (LC), 16000 Hz, mono, fltp
At least one output file must be specified
If I download the video from ZM and play in vlc I can scrub back and forth but I do get black screens while scrubbing and I don't get audio
This is the hidef from ZM:
(one thing I notice is the large 27095 kb/s)
mike@shark:~/Downloads$ ffmpeg -i 1253267-video.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '1253267-video.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 512
    compatible_brands: isomiso2avc1iso6mp41
    title           : Zoneminder Security Recording
    encoder         : Lavf58.20.100
  Duration: 00:00:17.54, start: 0.109678, bitrate: 27097 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 3840x2160, 27095 kb/s, 9.97 fps, 90k tbr, 90k tbn, 2000k tbc (default)
    Metadata:
      handler_name    : VideoHandler
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 16000 Hz, mono, fltp (default)
    Metadata:
      handler_name    : SoundHandler
This is the lodef downloaded from ZM
mike@shark:~/Downloads$ ffmpeg -i 1253287-video.mp4
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '1253287-video.mp4':
  Metadata:
    major_brand     : isom
    minor_version   : 512
  Duration: 00:10:00.13, start: 0.000000, bitrate: 327 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 640x360, 261 kb/s, 9.98 fps, 24.92 tbr, 16k tbn, 32k tbc (default)
    Metadata:
    Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 16000 Hz, mono, fltp, 64 kb/s (default)
    Metadata:
I have one other hidef camera and it works fine with the same setup.
Anyone got any ideas?
zm: v1.36.33
Installed via apt-get
linux: Debian buster
Andyrh
Re: Event recording
Post by Andyrh »
For the audio on the hidef monitor, make sure the box is checked to record audio.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
stinga
Re: Event recording
Post by stinga »
Thanks!
Yes it is
zm: v1.36.33
