I have one monitor with Source Type Ffmpeg configured.
top shows about 30% CPU usage by zmc process when Monitor in Modect mode and about 20% in Nodect mode. zmc consume this level cpu constantly not only when motion detected. When i disable this Monitor (set Function to None) zmc consumes almost nothing.
I suppose this because Zoneminder does not use hardware acceleration for camera video stream. When i check system gpu usage with intel_gpu_top it shows no gpu usage at all.
1) How to troubleshoot why this happened?
2) Is zoneminder supports hw acceleration for video stream decoding?
I tried set in Monitor config:
DecoderHWAccelName to vaapi and qsv
DecoderHWAccelDevice /dev/dri/renderD128
but nothing changed.
3) Are there any logs to check is hardware acceleration used for video stream decoding?
zmc process uses too much cpu for only one monitor
Re: zmc process uses too much cpu for only one monitor
Did you either restart zm or reboot?but nothing changed.
How many cores on this machine?
What is the camera sending and how is zm configured for it?
Yes i did.Did you either restart zm or reboot?
4 coresHow many cores on this machine?
I have attached screenshots from Monitor settings.What is the camera sending and how is zm configured for it?
- Снимок экрана 2024-05-29 104953.png (265.55 KiB) Viewed 599 times
- Снимок экрана 2024-05-29 105007.png (173.19 KiB) Viewed 599 times
- Снимок экрана 2024-05-29 105026.png (131.35 KiB) Viewed 599 times
more screenshots
- Снимок экрана 2024-05-29 105042.png (146.31 KiB) Viewed 597 times
- Снимок экрана 2024-05-29 105540.png (111.28 KiB) Viewed 597 times
- Снимок экрана 2024-05-29 105553.png (141.83 KiB) Viewed 597 times
Nothing screams at me there...may as well forget HWaccel for now. Last I heard and tried it, wasn't much help.
If you put that camera address in VLC, what does it report for the codec? 720 x 1280?
This graph shows how zmc process consumes CPU during last 2 days:
- Снимок экрана 2024-05-31 165107.png (200.08 KiB) Viewed 532 times
From the ZoneMiner wiki:
Does it use ffmpeg for decoding?
Do i need any config to enable harware acceleration for deconding?
Why source type has name Ffmpeg if it does not use ffmpeg executable???
Not a word about how ZoneMinder DECODE video stream from camera.Where is ffmpeg in Zoneminder?
See: viewtopic.php?t=32450
It shows the codec is h264 MPEG-4 AVC part 10, 1280 x 720:dougmccrary wrote: ↑Wed May 29, 2024 11:17 pm If you put that camera address in VLC, what does it report for the codec? 720 x 1280?
you could go to the camera's settings, and cut the framerate times .5 or even .1
Yes it is reduce cpu usage as following:
But the cost is video quality. 5fps video is horrible. It is not what i really want.
