when deleting events from list the page seems to refresh after deletion.
selecting and trying to delete another event(s) is not possible, the delete button is not active until the page is refreshed manually.
tried diferent browsers with same result.
Version: 1.37.59~20240410071521-jammy
[FIXED] - ISSUE/BUG - Event delete issue
Re: ISSUE/BUG - Event delete issue
There is likely a javascript error... can you right click, inspect element, go to console tab and see if anything useful is there?
check the attachment.
Inspect->Console when deleting 1 event and soon after marking another and trying to delete. The delete button is "grayed out".(not active)
"DATETIME_FORMAT_PATTERN" is empty in options
I had changed the "TIMEZONE" and "LOCALE_DEFAULT" to reflect the local time settings, that's all thats done
regards.
- delete-not-possible.jpg (229.79 KiB) Viewed 1587 times
Just pushed a fix. New packages are building.
