Failed INSERT INTO Server_Stats
Anna.N
Post by Anna.N »
Since a few days my log is filled with the following message every minute.
Failed INSERT INTO Server_Stats (ServerId, TimeStamp, CpuLoad, CpuUserPercent, CpuNicePercent, CpuSystemPercent, CpuIdlePercent, CpuUsagePercent, TotalMem, FreeMem, TotalSwap, FreeSwap) VALUES ('',NOW(),?,?,?,?,?,?,?,?,?,?) :Data truncated for column 'CpuLoad' at row 1
I have no clue where to look for. For the time being I just commented the lines out in zmstats.pl
(1.37.56~20240320.53-bookworm amd64)
Detlef Paschke
Re: Failed INSERT INTO Server_Stats
Post by Detlef Paschke »
t's the same here under Debian12, since today's update (1.37.56~20240320.53-bookworm) via (1.37.55~20240315.181-bookworm).
Best regards
Detlef Paschke
Anna.N
Post by Anna.N »
Remark: it only happens on debian bookworm on a amd64 PC. Even on a clean install. No problem on armhf and arm64 with bookworm.
Anna.N
Post by Anna.N »
After further investigation changing system locale from de_DE to en_US seem to have solved the problem.
Obviously the different decimal separator used in Germany caused the problem.
Turn on debug logging, it should log the values being sent.
Anna.N
Post by Anna.N »
As Expected:
de_DE Cpuload: 0,88 0,60 0,27
en_US Cpuload: 0.92 0.71 0.37
Current builds should have this fixed.
