Zoneminder setup Vs Wyze cameras
tater1337
Post by tater1337 »
Our local makerspace uses a tonton NVR for security, but the thing keeps having issues, and cannot handle as many cameras as we would like to use
the president is leaning towards using a bunch of Wyze Cameras, while I'd like to set up a zone minder setup for about 12-24 cameras
any suggestions as to why we should NOT use wyze cameras?
burger
Re: Zoneminder setup Vs Wyze cameras
Post by burger »
The general problem with running camera solutions like Wyze, or whatnot, is it may not be future proof. It's also closed source software. You depend upon their servers for either the app or the videos, and if they discontinue the service then you have useless equipment. If you get at least an ONVIF compatible camera system, then you can at some point choose to use Zoneminder in the future. It looks like Wyze is half/half on RTSP support, which is not something I would gamble on. See: https://forums.wyze.com/t/does-wyze-og-has-rtsp/255774 and https://www.reddit.com/r/wyzecam/commen ... ow_please/
With regards to Wyze with zoneminder:
https://wiki.zoneminder.com/Wyze_Cam
Search the forum for posts about Wyze. I've never used them personally.
For zoneminder camera recommendations see:
https://wiki.zoneminder.com/Beginner_hardware
https://wiki.zoneminder.com/Hardware_Compatibility_List
I personally am running used Axis cameras that are 2K at least. Hikvision or (I've never used but probably works) Dahua would also be good options.
fastest way to test streams:
