User interface crashes (HTTP 500) with workaround
gyzod
Post by gyzod »
Since yesterday's build, the user interface crashes on zoneminder 1.37.x. I've traced down the error to apache's error.log, which is :
[Wed Feb 21 18:02:24.241991 2024] [php:error] [pid 366342] [client 192.168.2.221:60826] PHP Fatal error:  Uncaught Error: Call to a member function CpuLoad() on null in /usr/share/zoneminder/www/skins/classic/includes/functions.php:410\nStack trace:\n#0 /usr/share/zoneminder/www/skins/classic/includes/functions.php(274): getSysLoadHTML()\n#1 /usr/share/zoneminder/www/skins/classic/includes/functions.php(186): getNormalNavBarHTML()\n#2 /usr/share/zoneminder/www/skins/classic/views/console.php(99): getNavBarHTML()\n#3 /usr/share/zoneminder/www/index.php(260): require_once('...')\n#4 {main}\n  thrown in /usr/share/zoneminder/www/skins/classic/includes/functions.php on line 410
[Wed Feb 21 18:02:39.589255 2024] [php:error] [pid 366398] [client 192.168.2.215:52296] PHP Fatal error:  Uncaught Error: Call to a member function CpuUsagePercent() on null in /usr/share/zoneminder/www/skins/classic/includes/functions.php:396\nStack trace:\n#0 /usr/share/zoneminder/www/skins/classic/includes/functions.php(275): getCpuUsageHTML()\n#1 /usr/share/zoneminder/www/skins/classic/includes/functions.php(186): getNormalNavBarHTML()\n#2 /usr/share/zoneminder/www/skins/classic/views/console.php(99): getNavBarHTML()\n#3 /usr/share/zoneminder/www/index.php(260): require_once('...')\n#4 {main}\n  thrown in /usr/share/zoneminder/www/skins/classic/includes/functions.php on line 396
By commenting these 2 lines, the user interface works fine !
OS : Ubuntu 22.04
Pat
borozenetsww
Re: User interface crashes (HTTP 500) with workaround
Post by borozenetsww »
Confirmed. ZM stop work at 1.37.51~20240221142147-jammy.
borozenetsww
Comment two lines for work.
// $result .= ' '.translate('Cpu').': '.number_format($thisServer->CpuUsagePercent(), 1, '.', '').'%'.PHP_EOL;
// $result .= ' '.translate('Load').': '.number_format($thisServer->CpuLoad(), 2, '.', '').PHP_EOL;
Now not show system load, but ZM work.
I get 1.36.12 - is this right, at the end of policy?
1.37.45~20230921.14-jammy 500
500 http://zmrepo.zoneminder.com/debian/master jammy/ Packages
*** 1.36.12+dfsg1-1ubuntu0.1~esm1 510
510 https://esm.ubuntu.com/apps/ubuntu jammy-apps-security/main amd64 Packages
100 /var/lib/dpkg/status
1.36.12+dfsg1-1 500
500 http://us.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
borozenetsww
dougmccrary wrote: Thu Feb 22, 2024 5:12 am I get 1.36.12 - is this right, at the end of policy?
1.36.12+dfsg1-1 500
1.36.33
https://launchpad.net/~iconnor/+archive ... lter=jammy
Thanks, but 1.37.xx is what I'm after.
I did manage to get the current .51, it's running, but the UI is majorly missing. Gotta be something simple...
The buttons across the top work, the console looks like
Screenshot 2024-02-22 at 00-50-36 Screenshot.png (75.11 KiB) Viewed 3785 times
borozenetsww
dougmccrary wrote: Thu Feb 22, 2024 8:34 am Thanks, but 1.37.xx is what I'm after.
edit - seems the www directory is empty. Anyone know how to re-populate it? install --reinstall zoneminder didn't do it.
Solution is above. Comment two lines. This is error in last build. I hope after update this error will be fixed.
Thank you sir!
I'd overlooked the intended fix wasn't ...
