Mastering ZM motion detection intricacies?
Re: Mastering ZM motion detection intricacies?
Before spending time on that, you'd probably have better luck with 1.36.xx, currently at 33 and proposed 34.
Nice post though.
mikb
Post by mikb »
dougmccrary wrote: Wed Feb 21, 2024 8:18 am Before spending time on that, you'd probably have better luck with 1.36.xx, currently at 33 and proposed 34.
Nice post though.
Do not encourage it. It was a recycled post.
viewtopic.php?p=127164&hilit=Ubiquiti+G3+Flex#p127164
with "daft language" filtering applied to it to prevent it being detected.
Fail.
MohanDavid
Post by MohanDavid »
Hey thanks! You're definitely right, fiddling with the current version might not be the most efficient use of time. Sticking with 1.36.xx (especially since there's an update coming) sounds like the smarter move. Appreciate the heads up!
