v1.37.51 zmdc.log uninitialized value
ihavealegohead
Post by ihavealegohead »
Interesting errors -- does not seem to cause any issues.
==> /var/log/zm/zmdc.log <==
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 376.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 378.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 380.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 389.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 391.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 393.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 395.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 397.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 399.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 401.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 403.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 405.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 407.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 409.
Use of uninitialized value in string eq at /usr/share/perl5/ZoneMinder/Filter.pm line 411.
Use of uninitialized value in string ne at /usr/share/perl5/ZoneMinder/Filter.pm line 413.
Re: v1.37.51 zmdc.log uninitialized value
Are you on the latest version of .51?
caused by undefined sort field. I just pushed a fix for the warning.
