ONVIF PresetToken wrong
Schokex
Post by Schokex »
I'm using a Chinese Cooau P4 PTZ Camera (Firmware says it is a Meari Speed B5T). It uses ONVIF for PTZ. With the OnVIF Device Manager I can set and call pan/tilt presets just fine. In ZoneMinder I can manually pan and tilt the camera, but I cannot set or call presets.
With Wireshark I found the difference:
ODM sends "PRESET_1" as PresetToken, Zoneminder sends just "1" when calling preset 1.
Here is the excerp from Wireshark:
ZoneMinder:
                <ProfileToken>
                    PROFILE_000
                    </ProfileToken>
                <PresetToken>
                    1
                    </PresetToken>
ODM:
                <ProfileToken>
                    PROFILE_000
                    </ProfileToken>
                <PresetToken>
                    PRESET_1
                    </PresetToken>
Is there any way I can change the PresetToken in Zoneminder and add the "PRESET_" before the preset number?
Thanks for the help!
Re: ONVIF PresetToken wrong
edit /usr/share/perl5/ZoneMinder/Control/Netcat.pm
Around lines 504 there are the preset functions, add the PRESET_ to the xml sent
Schokex
Post by Schokex »
Thanks for the info.
I did make some changes, but apparently it is not applied. ZoneMinder is still sending "1" instead of "PRESET_1".
Do I need to recompile?
You need to restart the zmcontrol process. you could do sudo killall zmcontrol.pl and it will kill them all. They will be restarted automatically
