Is it possible to receive a camera's motion events directly?
timw
Post by timw »
I've just moved to ZoneMinder after several years of using QNAP QVR. (More due to ditching my horrid QNAP box, as opposed to disliking QVR, which was rather good - when it worked).
Anyhow, I'm probably misunderstanding how ZM works, but QVR was able to capture motion events from the camera's on board capabilities and I don't see how to do that from within the ZM web interface.
I have 2 cameras. A ReoLink (RLC-410-5MP) and a Hikvision (DS-2CD2385FWD-I). They both have some basic on-board motion detection, and I'd prefer to harness this than burn CPU cycles on ZM-side frame analysis.
Is it possible to receive these camera events directly in ZM?, or do I need another piece of software to perform external triggering? I've read a bit about this, but I'm somewhat out of my depth on the topic.
I believe the Reolink is ONVIF compliant, but the Hikvision isn't (or perhaps it is partially). Ether way, I don't understand how the cameras' event broadcasting works, so I don't really know where to start.
Thanks in advance for any guidance!
Re: Is it possible to receive a camera's motion events directly?
Yes. Best to run the 1.37 dev series. You turn on ONVIF event listener, populate ONVIF url in the monitor settings and it basically just works.
timw
Post by timw »
Thanks for the reply. I'm running v1.36.33 via your Ubuntu PPA. Any idea when it will available in the stable release?
Never. Stable release does not get new features.
