Page 1 of 1
Minor web interface annoyance
Posted: Sat Aug 26, 2023 7:54 pm
by BiloxiGeek
When I access ZM via safari I my iPad I see some annoying behavior between landscape and portrait orientation. The list of events is overflowing the viewable space. I portrait I don't see the check boxes at all, landscape is slightly better but still not quite right. This isn't a zoom issue, I can't zoom out to see the whole interface at all. It's actually worse in chrome on the iPad, can't see the check boxes at all in both orientations.
Re: Minor web interface annoyance
Posted: Sun Aug 27, 2023 4:48 pm
by iconnor
I am somewhat aware of poor layouts on various devices...
One thing you can do is turn off some of the columns...
Posted: Sun Aug 27, 2023 6:27 pm
by BiloxiGeek
And there's my Duh moment for the weekend. Should have figured that one out on my own.
Posted: Mon Aug 28, 2023 2:22 pm
by BiloxiGeek
How do you set the default view? Deselecting some of the columns that I don't care about does fix the original problem. But when I go back into that view all the columns are in view again. How do I save the layout that I want as a default? Looked through options and didn't see any setting for this.
Posted: Mon Aug 28, 2023 3:35 pm
by BiloxiGeek
Just found this github issue with a fix that seems to work pretty well.
https://github.com/ZoneMinder/zoneminder/issues/3671
